    Recalbox 6.1.1 download links?
    recalbox 6.1.1 download links
    3906
    • Dwarf
      Dwarf last edited by
      Hi!
      I need the download link for Recalbox 6.1.1 for raspberry pi 3.
      I update to version 7.0, but he xinmo controller doesn't work for the second player, and the sound doesn't work, so i want to go back to the previous version, but i can't find it anymore...
      Thanks!
      RPi3 Recalbox 7.0.1 (Stable)
        Hello
        recalbox 6.1.1 is no longer available for download
        no more support available for this version.
        sound ? jack ?
        • Dwarf
          Sound hdmi. It works about 1-2 seconds on start and after that silence...
          Someone must have the 6.1.1 clean image, i just want to go back until 7.0.1 or something that fix this issues...
          I magange to fix te second player bug putting this line in the cmdli.txt: usbhid.quirks=0x16c0:0x05e0:0x040. Now i can have 2 players, but hotkey isn't working properly and i have to power-off the pi, can't exit the games...
            acris @Dwarf last edited by
            @Dwarf said in Recalbox 6.1.1 download links?:
            Check in Audio/sound Option in Emulationstation menu, try hdmi output or auto .
            strange with xin-mo, @ian57 any idea ?
            Dwarf 1 Reply Last reply Reply Quote 0
            • Dwarf
              Dwarf @acris last edited by Dwarf
              @acris Sorry, audio jack, i'm stupid... 😲 I try al the options in the config, still no sound.
              I think it isn't xin-mo but a clon, i had to use usbhid.quirks=0x16c0:0x05e0:0x040 instead of usbhid.quirks=0x16c0:0x05e1:0x040 (mine has a 0 instead of a 1 at the second identifier)
                try in recalbox.conf to modifiy line.
                Dwarf 2 Replies Last reply Reply Quote 0
                • Dwarf
                  @acris I use recalbox manager to configure it via web and it works, but on the next reboot it wasn't working anymore... I'm gonna try recalbox.conf.
                    recalbox manager is buggy, try with network share or winscp
                    • Dwarf
                      @acris
                      In recalbox.conf i edit this:
                      ------------ C - Audio ------------
                      Set the audio device (auto, hdmi, jack)
                      audio.device=Default output
                      And put this:
                      audio.device=auto
                      It works, but after reboot, it's mute again and in recalbox.conf is the initial configurtion again...
                        try with winscp software OR network share @Dwarf
                        it's better.
                        • Dwarf
                          @acris edited in the computer with notepad++, same result, first time it works perfect, after restart, sound only work 1-2 seconds of the intro video...
                          • Dwarf
                            It seems that the recalbox.conf file is reseting to a default version after reboot, this is what I see in Cyberduck:
                            When I modify it, the date was the current date, but after reset the date is 1/1/80
                              very strange
                              • Dwarf
                                @acris Yeah, on boot i get sound, but the file get reseted, so in next boot i got no sound...
                                Any ideas? I think i may go back to 6.1.1 for now, if i get the image...
                                Paulska 1 Reply Last reply Reply Quote 0
                                • Paulska
                                  Paulska @Dwarf last edited by
                                  @Dwarf
                                  I remember having this issue of my config file restoring itself in 6.1.1.
                                  But not sure if just trying over and over again didn't fix it.
                                  Also you can try shutdown and then turn it on again instead of restart. Also try shutdown and restart methods through the manager and through the box itself.
                                  Let me know if any work. Incase I come to this issue again
                                  • Dwarf
                                    Dwarf @Paulska last edited by
                                    @Paulska Sorry, i try anything, but it just keep resetting the config...
                                    I got the 6.1.1 version from a friend and go back to it, all is working properly again!
                                    Angelcdk 1 Reply Last reply Reply Quote 0
                                    • Angelcdk
                                      Angelcdk @Dwarf last edited by
                                      @Dwarf Hi,
                                      I have the same problem and would like to go back too, could you share me the 6.1.1 version ?
                                      • Dwarf
                                        Dwarf @Angelcdk last edited by
                                        @Angelcdk This is the link that send me a friend, it will work a few days more:
                                        https://wetransfer.com/downloads/bd89b87fe55933ce86ba1f3cd28a57f220201003112347/0698452a884ddaf3e4ed571fabac37cc20201003112409/d5df88
                                        • Angelcdk
                                          @Dwarf Thank you very much ! 😄
                                          • Dwarf
                                            @Angelcdk it's the raspberry pi 3 version, by the way!
