    Recalbox 7.0 Reloaded (Sortie Jack)
    recalbox 7.0 reloaded sortie
    14
    52
    12253
    • Laban
      Laban last edited by acris
      Les logs
      [4.58] Wifi option disabled
      [        6.17] [        4.58] Wifi option disabled
      es
      [        6.32] Will not start S13fbcp : system.fbcp.enabled is set to 0
      [        6.36] Running MIGRATIONS...
      [        6.81] modprobe: module usbhid not found in modules.dep
      [        6.98] starting new log
      [        6.99] converting dos to unix carriage return characters
      [        7.04] setting hostname to RECALBOX
      [        7.05] setting audio volume to 90
      [        7.07] setting keyboard layout to en
      [        7.08] ---- recalbox-config.sh ----
      [        7.10] setting audio volume : 90
      [        7.08] cannot open file en
      [        7.75] setting timezone to Europe/Paris
      [        7.06] Simple mixer control 'PCM',0
      [        7.06]   Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      [        7.06]   Playback channels: Mono
      [        7.06]   Limits: Playback -10239 - 400
      [        7.06]   Mono: Playback -662 [90%] [-6.62dB] [on]
      [        7.77] Setting volume for numid=3
      [        7.79] Setting volume for numid=2
      [        7.80] Setting volume for numid=1
      [        7.81] Setting volume for numid=5
      [        7.06] amixer: Control default element write error: Operation not permitted
      [        7.06]
      [        7.82] Setting volume for numid=4
      [        7.84] Force unmute on HDMI
      [        7.06]
      [        7.86] Force unmute on HDMI
      [        7.87] Restoring audio configuration
      [        7.88] setting audio to Default output
      [        7.90] ---- recalbox-config.sh ----
      [        7.93] Unknown audio format : Default
      [       15.95] starting xarcade2jstick
      [       16.31] xarcade2jstick : no official stick found, looking for keyboard encoder now ...
      [       27.08] starting emulationstation with lang = en_US
      [       27.15] emulationstation-starter started
      [       27.16] started emulationstation (pid=1057)
      [       27.19] S32mini TFT : Reading system.secondminitft.enabled => 0
      [       27.22] S32miniTFT not enabled
      [       27.25] ---- recalbox-config.sh ----
      [       28.41] Starting S92switch
      [       28.42] script /recalbox/scripts/powerswitch.sh [ STARTED ]
      [       28.52] Starting S94manager
      [       28.53] ... Starting manager v2
      [      264.51] ---- recalbox-config.sh ----
      [      264.78] enabled overclock mode : rpi3-turbo
      [      272.26] Stopping S94manager
      [      272.40] Stopping S92switch
      [      272.41] script /recalbox/scripts/powerswitch.sh already stopped !
      [      272.44] emulationstation exited code 0
      [      272.45] emulationstation-starter ended
      [      272.70] S32mini TFT : Reading system.secondminitft.enabled => 0
      [      272.72] S32miniTFT not enabled
      [      272.83] Stopping Emulationstation
      [      273.05] Stopping S13fbcp
      [      273.14] recalbox.conf saved to /boot partition
      La partie audio est bizarre dans le script de config
      if [ "$command" == "audio" ];then
          # this code is specific to the rpi
          # don't set it on other boards
          # find a more generic way would be nice
          rm /recalbox/share/system/.asoundrc 2>/dev/null
          if [[ "${arch}" =~ "rpi" && "auto hdmi jack" =~ "${mode}" ]]
          then
              # this is specific to the rpi
              cmdVal="0"
              if [ "$mode" == "hdmi" ];then
                  cmdVal="2"
              elif [ "$mode" == "jack" ];then
                  cmdVal="1"
              fi
              recallog "setting audio output mode : $mode"
              amixer cset numid=3 $cmdVal || exit 1
          elif echo "$mode" | grep -qE "^[[0-9]:[0-9]]"
          then
              cardId=`echo $mode | sed "s+^[\([0-9]\)\:\([0-9]\)].*+\1+g"`
              deviceId=`echo $mode | sed "s+^[\([0-9]\)\:\([0-9]\)].*+\2+g"`
              recallog "setting audio output mode : '$mode' => $cardId $deviceId"
              if [[ "${arch}" == "odroidxu4" && "${cardId}${deviceId}" == "00" ]]
              then
                  # this is specific to the xu4
                  # bypass the creation of the .asoundrc file for the default 0,0 device as the asound.conf is just enough
                  recallog "bypass the creation of .asoundrc file"
                  exit 0
              fi
              cat > /recalbox/share/system/.asoundrc << EOF
      pcm.!default {
              type hw
              card ${cardId}
              device ${deviceId}
      ctl.!default {
              type hw
              card ${cardId}
      EOF
              exit $?
          else
              recallog -e "Unknown audio format : $mode"
              exit 1
          fi
          exit 0
      fi
      • Axel Rousset
        Axel Rousset last edited by
        peut tu me dire quelle modif tu as faite , j'ai le même problème ? merci
        • Laban
          /recalbox/scripts/recalbox-config.sh audio
          cela fonctionne bien après
          Je regarde pour faire un workaround en lançant la commande avec emulationstation
          Axel Rousset acris 2 Replies Last reply Reply Quote 0
          • Axel Rousset
            Axel Rousset @Laban last edited by
            @Laban Merci de ta réponse hyper rapide !
            Malheureusement je saisie pas tout a fait .
            C'est pas du ssh ?
            c'est une commande à faire en local ?
            de mon coté j'avais l'habitude de triturer le fichier config.txt , à priori c'est pas la ?
            si tu peux m'aiguiller un chouilla plus je m'en sortirai Merci !
              acris @Laban last edited by
              @Laban said in Recalbox 7.0 Reloaded (Sortie Jack):
              tu as modifié quoi ?
              Axel Rousset 1 Reply Last reply Reply Quote 0
              • Axel Rousset
                Axel Rousset @acris last edited by
                @acris dans config.txt sans succes ..
                hdmi_safe=1
                hdmi_force_edid_audio=1
                hdmi_drive=2
                sinon , si mon raisonement est bon, j'ai compris qu'il fallait lancer un script mais je vois pas comment ..
                pouvez vous me donnez la manip pour avoir la main sur l'os éventuellement ?
                  ya pas de solution pour la sortie jack pour le moment, la team dev travaille sur le problème
                  merci de patienter , la team est en déplacement à Paris.
                  • Laban
                    Je suis en train de tester, mais mon workaround semble fonctionner en attendant un correctif des dev. Dès que j'ai fini mes tests, je vous donne la procédure
                    • nono7
                      nono7 last edited by
                      On va donc attendre que la team règle le problème alors, merci 😉
                      • Laban
                        Perso cela fonctionne, j'ai cependant du modifier le lanceur d'emulation station
                        Voici ce que j'ai fait :
                        J'ai me suis connecté en sftp sur recalbox (logiciel winscp / login root / mdp recalboxroot)
                        Je me suis posé dans le répertoire /etc/init.d et j'ai copié sur mon PC le fichier S32emulationstation que j'ai modifié comme cela
                        #!/bin/sh
                        systemsetting="recalbox_settings"
                        PIDFILE=/var/run/emulationstation.pid
                        ESBIN=/usr/bin/emulationstation-starter
                        scr_msg() {
                        	printf "\r%20s%10s" "${1}" " " > /dev/tty0 # with spaces at the begining for screen not displaying the left ; and spaces on right to erase old msg
                        case "$1" in
                          start)
                        	enabled="`$systemsetting -command load -key system.es.atstartup`"
                        	videoMode="`$systemsetting -command load -key system.es.videomode`"
                        	if [ "$enabled" != "0" ];then
                        		# get output video size
                        		fbdevHeight=$(cut -d, -f2 /sys/class/graphics/fb0/virtual_size)
                        		# In case the logo has been removed, let's put it back again
                        		if [ "${fbdevHeight}" -le 320 ] ; then
                        			fbv2 -f -i /recalbox/system/resources/splash/240p/logo-version.png
                        		else
                        			fbv2 -f -i /recalbox/system/resources/splash/logo-version.png
                        		fi
                        		echo $videoMode | grep -qE "(CEA|DMT) [0-9]{1,2} (HDMI|DVI)"
                        		[ $? = "0" ] && tvservice -e "$videoMode"
                        		settings_lang="`$systemsetting -command load -key system.language`"
                        		recallog "starting emulationstation with lang = $settings_lang"
                        		if grep -q rpi4 /recalbox/recalbox.arch; then
                        			HOME=/recalbox/share/system LANG="${settings_lang}.UTF-8" SDL_VIDEO_GL_DRIVER=/usr/lib/libGLESv2.so SDL_VIDEO_EGL_DRIVER=/usr/lib/libEGL.so SDL_NOMOUSE=1 start-stop-daemon -S -q -m -p /var/run/emulationstation.pid  --exec "$ESBIN" &
                        		else
                        			HOME=/recalbox/share/system LANG="${settings_lang}.UTF-8" SDL_VIDEO_GL_DRIVER=/usr/lib/libGLESv2.so SDL_VIDEO_EGL_DRIVER=/usr/lib/libGLESv2.so SDL_NOMOUSE=1 start-stop-daemon -S -q -m -p /var/run/emulationstation.pid  --exec "$ESBIN" &
                        		fi
                        	fi
                          stop)
                        	recallog "Stopping Emulationstation"
                        	start-stop-daemon -K -q -p "${PIDFILE}"
                        	clear > /dev/tty0
                        	(echo;echo;echo;echo;echo) > /dev/tty0
                        	scr_msg "Please DO NOT power off Recalbox, PLEASE WAIT !!!"
                          restart|reload)
                        	"$0" stop
                        	if [ -f "${PIDFILE}" ] ; then
                        		ESPID=`cat /var/run/emulationstation.pid 2>/dev/null`
                        		while `"$0" status > /dev/null` ; do
                        			sleep 0.1
                        		done
                        	fi
                        	"$0" start
                          status)
                        	ESPID=`cat ${PIDFILE} 2>/dev/null`
                        	if [ -f "${PIDFILE}" ] && `ps | grep -qE "^[[:space:]]*${ESPID}"` ; then
                        		echo "Emulationstation is running (pid `cat /var/run/emulationstation.pid`)"
                        		exit 0
                        	else
                        		echo "Emulationstation is stopped"
                        		exit 1
                        	fi
                        	echo "Usage: $0 {start|stop|restart}"
                        	exit 1
                        esac
                        exit $?
                        J'ai ensuite mis ce fichier dans le réperttoire /recalbox/share/system
                        Je me suis ensuite connect à recalbox avec putty avec le meme compte que winscp
                        la partition étant protégé en écriture, il faut lancer la commande
                        mount -o remount,rw /
                        ensuite on lance la copie
                        cp -f /recalbox/share/system/S31emulationstation /etc/init.d/
                        et on remet les droits
                        chmod 755 /etc/init.d/S31emulationstation
                        Hop pour ma part cela a parfaitement fonctionner.
                        • Laban
                          Laban last edited by Laban
                          Erreur dans le précédent message, que je ne peux bizarrement plus éditer
                          Le fichier est S31emulationstation
                          Cela donne donc :
                            @Laban
                            j ai corrigé ton sujet pour S32emulationstation.
                            Laban 1 Reply Last reply Reply Quote 0
                            • Laban
                              Laban @acris last edited by
                              @acris said in Recalbox 7.0 Reloaded (Sortie Jack):
                              @Laban
                              • gm03
                                gm03 last edited by
                                J'ai fait la modif, toujours pas de son pour moi ....
                                • Laban
                                  Laban @gm03 last edited by Laban
                                  @gm03 said in Recalbox 7.0 Reloaded (Sortie Jack):
                                  Essaie de lancer la commande
                                  pour voir en te connectant et donne le résultat. Indiques aussi la plateforme. Je suis sur un raspberry pi 3b+
                                  • gm03
                                    gm03 last edited by
                                    numid=3,iface=MIXER,name='PCM Playback Route'
                                    ; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
                                    : values=0
                                    PI2 pour moi ...
                                    Laban 2 Replies Last reply Reply Quote 0
                                    • Laban
                                      @gm03
                                      Est ce que cela relance le son ou toujours pas en lançant cette commande ?
                                      • gm03
                                        gm03 last edited by gm03
                                        Non ca fait rien .. ca relance pas le son
                                        • Laban
                                          This post is deleted!
                                          • Laban
                                            Laban @gm03 last edited by acris
                                            @gm03
                                            Est ce que le fait d'éditer le fichier à la main depuis l'interface web et redémarrant fonctionnait (il fallait cependant arrêter emulationstation avant avec la commande /etc/init.d/S31emulationstation stop )
