    xinit : connection refused & Wi-Fi issue
    xinit connection refused wi-fi issue
    • Aeris
      Aeris last edited by
      Hi,
      Just flashed RecalBox (PC 64bits) to a 32Gb Class 10 SD Card and got my PC to boot on it.
      First start : connected with Ethernet, all great except Wi-Fi (even with Ethernet disconnected), reboot in order to fix the Wi-Fi
      Second start : xinit : connection refused, after some searches on this forum, I tried to resize the partitions on the card because the second one was full at 76%:
      BOOT 64Mb->64Mb
      RECALBOX 3Gb->6Gb
      SHARED 29Gb->26Gb
      Third start : Same error, connected with SSH and tried startx, ES started ! But Wi-Fi still not working (I've a TPLink WN725N dongle which is in compatibility list and all is great : WPA/not WEP, canal 11) 😕
      Can you help me solving these two problems ? I don't want to have to connect with Ethernet cable then using SSH and startx and finally connect to the TV (which is in a room without possibility to use an Ethernet cable)...
      Thanks,
      Aeris.
        Zing Global moderator Translator @Aeris last edited by
        @Aeris You should not change the size of the "boot" and "recalbox" partitions.
        You can at most shrink or enlarge the SHARE partition (but even that can cause problems if not done correctly).
        I recommend reinstalling the system, and not changing the size of the first two partitions.
