    Daphne - dapinput.ini
    Emulator Arcade/PC/Console
    daphne dapinput.ini
    • sroach
      sroach last edited by
      Hello,
      I am noticing a problem, in configs/daphne there is a file called dapinput.ini and you can use it to set your button maps.
      after editing this file and starting Daphne and running a game (Dragon's Lair) dapinput.ini gets overwritten with different inputs.
      Does anyone know what is overwriting this file and where it's getting the inputs it overwrites with?
      • sroach
        Never mind, just found post in Italian that pointed me to this..
        if you put the following in the Recalbox.ini it will read the file and not create one:
        daphne.configfile=/recalbox/share/system/configs/daphne/dapinput.ini
        Thank you @megane72
        • clkgames
          clkgames last edited by
          You can also edit recalbox/share/system/recalbox.conf and include de following line at the end of the file:
          daphne.configfile=dummy
          Tip: you can use this on any core should you need to edit its config file and it keeps getting rewritten by the system's scripts.
