    Recalbox starts on logo screen, then black screen and RPI never turns on again
    recalbox starts logo never turns
    1620
    • hrqmonteiro
      hrqmonteiro last edited by
      Hi, i found an old Rpi2 yesterday, which have Recalbox installed (from 2016 or so), then i removed and installed OSMC and used it normally. Then i decided to install emulators again, so i downloaded the latest recalbox pi2 image and flashed it.
      But it simply turns on the Logo Screen (Loading Screen) and then goes to black screen, and after that if i turn my pi off and tries to turn it on again, it doesnt even light the lights up. And i have to remove from SD and flash anything else again.
      Any help please.
      • guicln
        guicln last edited by
        Hi @hrqmonteiro,
        Did you try to edit config.txt ? It could be due to a bad boot resolution with your screen.
        These manuals will help you :
        https://github.com/recalbox/recalbox-os/wiki/Edit-the-config.txt-file-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-DVI-screen-(EN)
        hrqmonteiro 1 Reply Last reply Reply Quote 0
          paradadf Staff @hrqmonteiro last edited by
          @hrqmonteiro you probably didn‘t wait enough on first boot for the share partition to be properly created. Re-flash the sd card and wait as long as needed until recalbox boots up. And of course, aleways turn it off safely from the menu.
          • hrqmonteiro
            hrqmonteiro @paradadf last edited by
            @paradadf
            It stayed on for about 10 minutes, And have you check the part when i wrote that the Pi lights went off? This is the strangest part for me
            • hrqmonteiro
              hrqmonteiro @guicln last edited by
              @guicln I didn't think of that, but i'll check.
                @hrqmonteiro I read everything you wrote, yes.
                101.4k
