    Solved Amiga on Recalbox PC / USB
    Emulator Arcade/PC/Console
    amiga recalbox usb
    2321
    • Juvava
      Juvava last edited by
      Hello, I have been searching the Forum, did find a few other people with a similar problem, but no solution:
      trying to run Amiga Games on Recalbox 6.1.1 on my PC via USB Stick.
      Two USB Sticks, one for the Recalbox-Boot-Program and another one for all the Bios and ROMs.
      So far, all Systems are running, Emulation of Amstrad, SNES etc no problem.
      BUT: Amiga600 Games ONLY start when using adf (= Disk) Files. LHA Files won't start - they show up in the list but I get kicked back to the menu screen as soon as I try to start a game.
      Are LHA Files maybe only working on raspberry?
      All the Bios and Roms are named correctly, MD5 checked and in the right directory.
      Any idea what else I could try out?
      Thanks very much in advance!
        Scavy Global moderator @Juvava last edited by
        @Juvava hi
        all my .lha packed whdl roms work fine.
        Are all your bioses ok ? Are you sure that your .lha roms are ok ?
        Juvava 1 Reply Last reply Reply Quote 0
        • Juvava
          Juvava @Scavy last edited by
          @Scavy Thanks for your answer and offer to help.
          Thing is, I can't check my Bios with Recalbox Manager, as I don't get a Wlan connection...
          But I am 99% sure, that they are all ok - I checked all the MD5's...
          Only possibility is that I am missing one particular ROM that is needed for LHA.
          But why would afd work then?
          Strange and a bit frustrating.
          • Zaphod
            Zaphod last edited by Zaphod
            are there any messages in the recalbox log?
            use this command right after trying to launch a game
            tail /recalbox/share/system/logs/recalbox.log
            And also
            tail /recalbox/share/system/logs/es_launch_stderr.log
              paradadf Staff last edited by
              puae does support .lha on pc (as amiberry is only available on rpi), but I haven't had the time to test it in the latest version (available on the next release). On 6.1.1 I believe it is a bit more complex to make it work... some stuff has been changed on the core lately which should make everything a bit simpler. You I'd just wait for the next release.
              Zaphod Scavy Juvava 3 Replies Last reply Reply Quote 1
              • Zaphod
                Zaphod @paradadf last edited by
                @paradadf said in Amiga on Recalbox PC / USB:
                😬 so excited 😬
                  Scavy Global moderator @paradadf last edited by
                  @Zaphod woouups, i had in mind you were on a Pi, and you are on a PC, so it's normal as paradadf says...
                  • Juvava
                    Juvava @paradadf last edited by
                    @paradadf Just to make it clear for me: you are saying that it could be the case that lha on PC does not work with 6.1.1?
                    That's ok with me, at least I know I don't have to look any further.
                    Hopefully the problem will get solved in a new release.
                    Thanks!
                      @Juvava RCB uses P-uae on PC x64, and uses Amiberry (default emultor) on RPI3.
                      P-uae does not support .lha, Amiberry supports this format.
                      • Juvava
                        @Scavy Thanks Mate, that helps a lot. Would have saved me hours, had I found out in advance 🙂
