    Recalbox 6.1.1 stuck on splash screen with Pacman.
    recalbox 6.1.1 stuck splash pacman
    • fp69
      fp69 last edited by
      Hello,
      After a hard electric unplug of my raspberry Pi, Recalbox is freezed on the splash screen with the pacman.
      This is the 6.1.1-Dragonblaze 2019/11/13 14:16 release.
      I logged via the SSH on root, and used df to see that the root partition mounted on / is full at 100%.
      Maybe it's linked? If it is, I don't know what to delete without crashing the system.
      But by memory it seems that it's a while that it's full at 100% and I managed to make lots of power off/on without problem until the hard unplug.
      Can you help me investigate this problem please?
      Thanks in advance
        Zing Global moderator Translator @fp69 last edited by
        @fp69 It may have corrupted the installation, use an adapter and try to scandisk the SD card, but if that doesn't work, just reinstall the system.
        fp69 1 Reply Last reply Reply Quote 0
        • fp69
          fp69 @Zing last edited by
          @Zing Thanks for your answer. I made a check, it found an error, but it didn't change anything. So I reinstalled from scratch, it rebooted, but after I said the storage is ANYEXTERNAL, same pb.
          Then I said to myself maybe it's the USB key which had a pb.
          Then I scanned it and it found some corrupted sectors and repaired it, now it works again.
          Thanks for your help, have a nice day!
          101.4k
