    Issue When Exiting RetroArch
    issue exiting retroarch
    1845
    • gotogooch
      gotogooch last edited by
      Hey, all. Recently whenever I exit RetroArch to head back to the main Recalbox UI, it appears to crash. The screen goes black but then never boots back up again. Any ideas? Thanks in advance.
      OyyoDams Zing 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @gotogooch last edited by
        @gotogooch hey, as requested on discord, can you post a support archive ?
        • gotogooch
          I apologize for being difficult. I think I figured it out:
          https://transfer.sh/i4Rpz/recalbox-support-61b2f872-dfd7-aba9-40b9-2691a0571e54.tar.gz
            @gotogooch your "8BitDo M30 gamepad" is not mapped correctly.
            Please ensure pageup and pagedown are detected as "buttons" and not "axis"
            gotogooch 1 Reply Last reply Reply Quote 1
            • gotogooch
              gotogooch @OyyoDams last edited by
              @OyyoDams Thanks. I did that and the issue persists. I mapped them to the "Z" and "C" buttons, respectively, on the M30. I feel I should also note the issue appeared when the M30 hadn't been connected for a while.
                Zing Global moderator Translator @gotogooch last edited by
                @gotogooch said in Issue When Exiting RetroArch:
                I saw a user reporting a similar problem, in this case, the problem was the songs with the wrong frequency in his theme, did you edit the songs on the standard theme, or are you using a custom theme?
                gotogooch 1 Reply Last reply Reply Quote 0
                • gotogooch
                  gotogooch @Zing last edited by
                  @Zing Yes! I did mess around with editing the songs to lower their volume. I find the menu music to be drastically louder than the emulators. Can you please tell me the frequency they should be? Thank you for your suggestion.
                    @gotogooch I believe the correct definition is in this link:
                    https://github.com/recalbox/recalbox-os/wiki/Add-Custom-Music-to-EmulationStation-(EN)
                    • gotogooch
                      @Zing This solved my issue thank you so much!
