    HOW TO CHANGE Frontend commands?
    frontend commands?
    2021
    • PanJanDrum
      PanJanDrum last edited by
      Hello everyone, I am a fan from China.
      I want to ask you a question, I hope you can help me answer it.
      My device is Gpicase
      I checked the manual and wanted to change a frontend setting.
      I want to change it to A = Select B = Back How can I change it?
      This is more in line with the Asian habits.
        Hello
        Remap in emulationstation menu > gamepad options > configure gamepad
          paradadf Staff @acris last edited by
          @acris no, that’s not the way of doing it. Doing so will also map the buttons in-game incorrectly.
          @PanJanDrum the truth is that there is still no easy way of changing the controls in EmulationStation. The only thing easy to change is the controls wihtin retroarch’s menu (swap A and B inside retroarch), but that’s not exactly what you are asking and I don’t remember the name of the entry to change either (it should be self-explnatory though).
          PanJanDrum 1 Reply Last reply Reply Quote 0
          • PanJanDrum
            PanJanDrum @paradadf last edited by
            @paradadf said in HOW TO CHANGE Frontend commands?:
            Thank you very much for your answer.
            In addition, I would like to know how to modify the default PISNES and PIFBA simulator screen ratio in Gpicase. I want to adjust the picture ratio of SNES to 8: 7 FBA to full screen. The picture ratio looks a little strange now.
            • A Former User
              A Former User last edited by A Former User
              hello You have go to controller and you have to go to configure controller and you must press long on a button ,wait and you have to do with your joystick the positions of joystick and buttons by pressing the button he tells you to put and now your controller is configured
                paradadf Staff @PanJanDrum last edited by
                @panjandrum maybe @Bkg2k knows? 😉
                • MadGear
                  MadGear last edited by
                  Hello!
                  Same here, I am used to japanese/asia button mapping too
                  snes a / ps o = confirm
                  snes b / ps x = cancel
                  It would be nice to have a setting allowing to swap these two buttons for the fontend commands.
                  (as paradadf mentionned, not remapping the controller button because in game buttons will be incorrectly remapped, just swap a/b in fontend).
