    Libretro Flycast - Per-Pixel Alpha Sorting
    Emulator Arcade/PC/Console
    libretro flycast per-pixel alpha sorting
    • turnedmyworld
      turnedmyworld last edited by
      Hello All,
      First I am using Batocera, not Recalbox (but from what I understand they are pretty closely related). I have posted my issue on the forum there and have received no help. It has been almost two weeks so I figured I would give this a try as I am out of options.
      I am trying to get a game to work on Flycast but need per-pixel alpha sorting for it to display correctly. The problem is that Retroarch only gives me two options:
      Per-Triangle and Per-Strip
      From what I can tell it looks like I need to change "enable OIT=0" to "enable OIT=1" in the Makefile. I have no idea what or where the Makefile is.
      Is this file included in these builds or is it something I can generate? I am really hoping there is a solution to this problem.
      My system is a Pentium dual core cpu with an Nvidia GTX 1050 and 4 gigs of RAM. I am using the latest 64bit release of Batocera.
      Thanks so much for any help that can be provided.
        Hello
        Sorry but recalbox forum here.
        No support for other system.
        You need to post your problem on batocera forum.
