    Recalbox terminal root password not working
    recalbox terminal root password
    • anegrich86
      anegrich86 last edited by anegrich86
      1_1575659295635_signal-2019-12-06-135220.jpg 0_1575659295631_signal-2019-12-06-135110.jpg
      Latest Recalbox installed on raspberry pi 3b with retroflag nespi+ case. Tried to login as root through the terminal for purpose of downloading/installing the safeshutdown scripts for using the power button on the case. I can type in the username (root), but when prompted for the root password (recalboxroot) it acts as though nothing is happening, i type the password hit enter, and nothing actually happens. even tried through SSH and same result. tried researching everywhere and found no useful answers on how to fix this issue. Anything's appreciated, thank you!
        OyyoDams Staff @anegrich86 last edited by
        @anegrich86 according to your screenshots, you're logged succesfully!
        anegrich86 1 Reply Last reply Reply Quote 0
        • anegrich86
          anegrich86 @OyyoDams last edited by
          @oyyodams it will show folder contents via ls command, however like I said when I type the root password and hit enter it does nothing but return to the hashtag, and won't let me continue Amy further disallowing me to get and install the scripts I need..very strange problem and still no progress
          OyyoDams paradadf 2 Replies Last reply Reply Quote 0
            @anegrich86 I don't understand... If lscommand works, then you ARE logged! Why do you want to enter root password again once you're logged ?
              paradadf Staff @anegrich86 last edited by
              @anegrich86 the hashtag # indicates you can type the commands you want.
