    Why i can't make pc engine isos work?
    engine isos
    5015
    • 8bit_astronaut
      8bit_astronaut last edited by
      I downloaded 3 versions of the syscard3.pce, also, tried a lot of games but doesnt work. Why? i don't know. I just want to play chi no rinne but it looks imposible šŸ˜•
        paradadf Staff last edited by
        Are you trying with one of these extensions: .pce/.cue/.ccd/.sgx or its respective .zip?
        • 8bit_astronaut
          i can't find the games in .ccd or .sgx The .cue is the only one that load, but i return me to the main menu
          • swisstoni
            swisstoni last edited by
            Im having the same problems anyone found a solution or do PC Engine CD games just not work full stop on the new version?
              voljega Banned last edited by
              Rename any uppercade extension on both bin/cue files to lower case. Edit your cue file and rename reference to bin file with the correct name (case included)
              • swisstoni
                Thanks for the reply,Ā ive changed the bin and cue file and managed to get to the CD rom screen it asks to press run to continue then I get a load error, the syscard3 isĀ in theĀ roms and bios directoriesĀ along with the CD rom bios files and ive tried a different one but it still not working?
                  bios syscard3 to add in bios folder. Use recalbox-manager to drop bios file and check md5 : https://github.com/recalbox/recalbox-os/wiki/recalbox-manager-WEB-interface-(FR) What game do you try ?
                  • swisstoni
                    R-Type and Dracula X, the syscard3 bios and md5 check out file in Recalbox Manager (ive even deleted the bios and tried a different one), any chance you could please tell me exactly how your files are named for any game you have working, totally baffled by this one its the only system I cannot get to work.
                      go to irc to help you : https://kiwiirc.com/client/irc.freenode.net/#recalbox
                      Copyright Ā© 2021 recalbox.com
