    Solved Still sound problems with Atari 5200 and 800 games
    still sound atari 5200 800
    7
    13
    4163
    • jorgemagana
      jorgemagana last edited by jorgemagana
      Hello, today I made a fresh install of 6.1.1 and the sound problem reported in this post (now closed) continues:
      https://forum.recalbox.com/topic/18980/problems-with-atari-800xl-emulator-with-raspberry-pi-3b-and-recalbox-6-0-6-1
      With 6.0 there aren't any audio problems, but since 6.1 a noise is present in every atari 5200 and 800 game.
      I am using Rasp 3b+
      juliantx 1 Reply Last reply Reply Quote 1
      • juliantx
        juliantx @jorgemagana last edited by
        Hello, I solved that problem with hotkey + B in the Retroarch configuration you select Options/Video Standard and change NTSC by PAL
        jorgemagana 1 Reply Last reply Reply Quote 0
        • jorgemagana
          jorgemagana @juliantx last edited by
          @juliantx thanks, but is a partial solution, games like Joust and others do not start if select PAL. I do not know why there is a PAL option in RA if 5200 never release PAL versions of the games... It is weird, but thanks!
          • jorgemagana
            Hello! Any news about this problem? Thanks
              paradadf Staff @jorgemagana last edited by
              @jorgemagana I recently b*mped the core and many audio related bugs should be fixed now. Please try it our as soon as the next update is available and let us know.
              jorgemagana EternaX 3 Replies Last reply Reply Quote 0
              • jorgemagana
                jorgemagana @paradadf last edited by
                @paradadf said in Still sound problems with Atari 5200 and 800 games:
                Thanks!
                • EternaX
                  EternaX @paradadf last edited by EternaX
                  I'm also using RB 6.1.1 and have that noises that superpose the game's sound on Atari 800 games.
                  Is there already an update available?
                  When I check the system settings' update section it doesn't show me any updates available.
                  DacK 1 Reply Last reply Reply Quote 0
                  • DacK
                    DacK @EternaX last edited by
                    @EternaX Update won't work from v6 to v7.
                    To get v7.1.1 you must make a fresh install on your uSD using Raspberry Pi Imager. 🙂
                    • jorgemagana
                      Sound problems are gone in 7.1.1, thanks!
                      • EternaX
                        I updated from 6.1.1. to 7.1.1. and the Sound problems on Atari 800 games still persist. A high frequent noise superposes the game sound
                        • clkgames
                          clkgames last edited by
                          Recalbox 7.1.1
                          Raspberry Pi 2GB
                          I can confirm the pitch noise plays on all games I've tried. No matter what (limited) options I change, the noise still plays.
                          • clkgames
                            I've found a fix, in case someone needs a help with this issue as well.
                            Load a game, then press Select +B to bring up the Retroarch menu.
                            From there, press A and go to Configurations > Audio.
                            Now set the audio volume and mixer volume to -10.
                            Hope it helps.
                            Regards,
                            John.
                              Scavy Global moderator @clkgames last edited by
                              @clkgames thanx 4 your feedback 🙂
