    Solved How to set up AI Translation services in recalbox?
    translation services recalbox
    • kelv
      kelv last edited by
      Hello
      I turned on Ai Translation services in retroarch but I don't see it working. is there any extra set up needed?
      thx
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
      • Bkg2k
        Bkg2k Staff last edited by
        Look into the recalbox.conf file from the webmanager, everything is explained inside.
        • Fishou
          Fishou last edited by
          Hello,
          There are some additionnal steps to be had, there is no current english documentation on that, so I will fill you in in the meantime.
          First, you need a Ztranslate account on https://ztranslate.net/ . Once that is done, you need to log in in the ztranslate website, then go to Settings.
          In there, you will find your API KEY (you shouldn't share it).
          Once that is done, you have to edit your recalbox.conf file (accesible with the webmanager), and search for the line containing
          • ;global.translate.apikey=YOUR_API_KEY_HERE
            delete the semi-colon and replace YOUR_API_KEY_HERE with the API KEY you found on Ztranslate
          Save the changes, then try launching a game and doing Hotkey+LeftJoystickDown
          Si vous débutez, je vous recommande de lire le glossaire.
          Je fais actuellement le Surchargeur RA, il est fourni tel quel, sans garanties.
          • kelv
            kelv last edited by
            Thank you!!! I did. I wasn't aware the steps where there. I had to set up the hotkey as it was the one you told me. Is there any way in speech mode that it will be reading continuously without clicking buttons?
            thx
            101.4k
