    Solved PSX, PSP and N64 emulators not showing up in the main menu
    Emulator Arcade/PC/Console
    psp n64 psx roms
    4305
    • Cloud Striker
      Cloud Striker last edited by Cloud Striker
      Hey, I recently upgraded my Recalbox from a 16GB SD card to one with 128GB. Everything seems to be working fine, except for the above mentioned systems not showing up in the list despite me definitely putting the relevant ROM files(Some zipped and others not) into the correct folders. My Recalbox operates on a Raspberry Pi 3B+ which is less than a week old.
      paradadf joinski 2 Replies Last reply Reply Quote 0
        paradadf Staff @Cloud Striker last edited by paradadf
        @cloud-striker verify the allowed extensions
        No zip on n64, bin need cue files on psx (no zip files either) and psp I don‘t remember.
        Cloud Striker 1 Reply Last reply Reply Quote 0
        • joinski
          joinski @Cloud Striker last edited by
          This post is deleted!
          • Cloud Striker
            Cloud Striker @paradadf last edited by
            @paradadf So I need to unzip all the N64 and PSX ROMs?
            • abunille
              abunille @Cloud Striker last edited by
              @cloud-striker
              yes.
              Sorry, but is it really so hard to look into the _readme.txt file on each system folder?
              Cloud Striker 1 Reply Last reply Reply Quote 2
              • Cloud Striker
                Cloud Striker @abunille last edited by
                @abunille Sorry for the kind of obvious question then. I didn't even realize that there were any readmes. Thanks for the response though!
