    Please help - cannot find wiring diagram for xinmo 2018
    GamePad/GPIO/USB encoder
    please help cannot find wiring
    • mrretro
      mrretro last edited by
      Hi everyone a while back (2 years) i built an arcade and used xinmo and used the wiring diagram in the wiki and it worked great.
      Now im building a better machine. the problem is xinmo board has changed, it has many more pins and i cannot find wiring diagram. please help !
        voljega Banned @mrretro last edited by
        @mrretro you should contact your vendor, he should have given you a paper with the diagram... or check the product' page, sometime it is there
        • mrretro
          found the solution (for anyone elses ref)
          http://www.xin-mo.com/dual_player.html
          • Eptdqcn41700
            Eptdqcn41700 last edited by
            Hello @mrretro
            I had to re-control everything, the wiring file had nothing to do with the received Xin-mo (commissioned in February 2019)!
            I create my own file for.. do not forget!
