    Kodi does not start
    MediaCenter & Dualboot
    kodi does start
    3212
    • Kleinray
      Kleinray last edited by
      Hi,
      I have installed Recalbox 6 and everything seems to work just fine.
      But I can't start Kodi. The problem that kodi does not start with some Gamepads is still present.
      QUMOX 2.4GHz Gamepad Joystick Joypad Game Controller für PC Android (ttps://www.amazon.de/QUMOX-Gamepad-Joystick-Controller-Android/dp/B01LX5UTSL/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&keywords=Qumox+gamepad&qid=1558789891&s=gateway&sr=8-1).
      If someone has a solution, you are welcome.
      Thanks
      Nazikus 1 Reply Last reply Reply Quote 0
      • Nazikus
        Nazikus last edited by
        I have the same problem. recalbox 6.0 + raspberry pi 3.
        When I start kodi, a boot screen appears, then a black screen, then return to the games menu.
        Reconfiguring gamepads does not solve the problem.
        • Nazikus
          Problem found.
          As it turned out, Kodi conflicts with the 2.4G Wireless GamePad working via USB adapter. If i disconnect this adapter, Kodi loads without problems.
          It would be great if the developers have fixed this bug, or someone suggested the setting in Kodi that will solve this problem.
            paradadf Staff @Nazikus last edited by
            @nazikus can you make a support archive with only that gamepad connected and right after the failed start of kodi?
            • Nazikus
              Nazikus @paradadf last edited by
              @paradadf said in Kodi does not start:
              How to do it? I do not know what the "support archive" is.
              • Nazikus
                Nazikus @Kleinray last edited by
                @kleinray said in Kodi does not start:
                https://www.amazon.de/QUMOX-Gamepad-Joystick-Controller-Android/dp/B01LX5UTSL/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&keywords=Qumox+gamepad&qid=1558789891&s=gateway&sr=8-1
                I have exactly such a gamepad. Owing to this gamepad - kodi does not start.
                My here:
                https://aliexpress.com/item/32834602683.html?spm=a2g0s.9042311.0.0.274233edPzG9o5
                • Shira
                  Shira last edited by
                  Same issue here, haven't been able to use Kodi for the past 2 years, currently with a Logitech F710 gamepad.
                  • MARCUS VINICIUS
                    MARCUS VINICIUS last edited by
                    Same problem with a Logitech gamepad cordless precision.
