    Solved Problem when adding new system to recalbox 6.0
    Community projects
    adding recalbox 6.0
    4883
    • Jaimebm1229
      Jaimebm1229 last edited by
      Good companions, I followed a tutorial to add more systems to the recalbox in this case the SNES MSU- 1
      This being the line that I added
      <system>
      <fullname>SNES MSU-1</fullname>
      <name>snesmsu1</name>
      <path>/recalbox/share/roms/snesmsu1</path>
      <extension>.st .ST .smc .SMC .sfc .SFC .fig .FIG .zip .ZIP</extension>
      <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO% %NETPLAY%</command>
      <platform>snesmsu1</platform>
      <theme>snesmsu1</theme>
      <emulators>
      <emulator name="libretro">
      <cores>
      <core>snes9x</core>
      </cores>
      </emulator>
      </emulators>
      </system>
      All right up there, I appear in the MENU, the games also, in advanced configuration of the emulator also appear the "core"
      but when you give it "launch game" it pretends to load it but it returns me to the list of the games again. If I move the roms from snesmsu1 to snes if they work then it's not a problem for the roms ..
      I'm using recalbox 6.0 in RPI 3b +
      HELP 😞
      Pd: Translated from Spanish with google translator
      paradadf Jaimebm1229 2 Replies Last reply Reply Quote 0
        paradadf Staff @Jaimebm1229 last edited by paradadf
        @jaimebm1229 have you compared it with, for instance, satellaview entry on es_system.cfg? Satellaview should look like exactly what you need besides the names.
        I don‘t remember if you‘d need to explicitly force the core within recalbox.conf, otherwise configgen wouldn’t know what to do. But I suppose you could do it from the ES Menu.
        Which file extension does msu1 games use?
        • Jaimebm1229
          Jaimebm1229 @Jaimebm1229 last edited by
          @paradadf With MSU-1 I made a clone of the SNES entry by varying fields like "snes" with "snesmsu1". it also happens to me with CPS
          I take this line as a reference
          ORIGINAL
          <system>
          <fullname>FinalBurn Alpha</fullname>
          <name>fba_libretro</name>
          <path>/recalbox/share/roms/fba_libretro</path>
          <extension>.zip .ZIP .fba .FBA .7z .7Z</extension>
          <platform>arcade</platform>
          <theme>fba_libretro</theme>
          <emulators>
          <cores>
          <core>fbalpha</core>
          </cores>
          </emulator>
          </emulators>
          </system>
          CPS MODIFICADA
          <system>
          <fullname>CPS</fullname>
          <name>cps</name>
          <path>/recalbox/share/roms/cps</path>
          <platform>cps</platform>
          <theme>cps</theme>
          <emulators>
          <cores>
          </cores>
          </emulator>
          </emulators>
          </system>
          But it gives me the same result, it appears in the menu and in the list of games too. but when you give it a game, it does not load it.
            @jaimebm1229 one step at a time. Please use the satellaview entry as a template for your snes msu1, as only the words „satellaview“ would need to be changed, nothing else.
            And try to force the core either from ES or directly editing recalbox.conf.
            • Jaimebm1229
              Jaimebm1229 @paradadf last edited by
              @paradadf Ok I'm going to do that. What line do I have to edit in recalbox.conf?
              • Jaimebm1229
                Jaimebm1229 @paradadf last edited by Jaimebm1229
                @paradadf The same symptom appears in the menu but does not load the games.
                they only work by modifying the systems already added.
                but keeping this line specific to any system.
                <name> *** </ name>
                Example.
                <system>
                <name><name>satellaview</name>
                <extension>.bs .BS .smc .SMC .sfc .SFC .zip .ZIP</extension>
                <emulators>
                <cores>
                <core>snes9x</core>
                </cores>
                </emulator>
                </emulators>
                </system>
                  @jaimebm1229 you must change the name too (snesmsu1). That line looks weird though... it starts with something double; you must have copied it wrongly.
                  Which extension do msu1 games have? What’s the launcher? You‘ll need to change that too.
                  What happen when you edit metadata on the gane you want to start and you try to force the emulator and core to libretro and snes9x respectively?
                  If the previous steps don‘t work, try adding the following lines to recalbox.conf:
                  snesmsu1.emulator=libretro
                  snesmsu1.core=snes9x
                  Double-check those lines are only present once in recalbox.conf.
                  Jaimebm1229 1 Reply Last reply Reply Quote 0
                  • Jaimebm1229
                    @paradadf something like this appears
                    Configurations generated by Recalbox
                    snesmsu1.flatfolder=0
                    snesmsu1.sort=0
                      @jaimebm1229 that looks good.
                      • Jaimebm1229
                        @paradadf But still, the games do not load me. I mean if I move the roms from snesmsu1 to snes if they work. or from cps1 to fba_libreto also work.
                        • Jaimebm1229
                          @paradadf https://forum.recalbox.com/topic/13244/recalbox-next-add-custom-systems
                            @jaimebm1229 did you correct the name? And for the third time... which file extension do the msu1 games use?
                            • Jaimebm1229
                              @paradadf thank you very much for the time spent 🙂 I could solve it, just reinstall recalbox again and start with the process from scratch. now if I load the games in the separate system "SNES MSU-1"
                              paradadf Ricardo Dicky 2 Replies Last reply Reply Quote 0
                                @jaimebm1229 glad it worked. Have fun playing!
                                • Ricardo Dicky
                                  Ricardo Dicky @Jaimebm1229 last edited by
                                  @jaimebm1229 Can you demonstrate how you did to add the system? thx
                                  • Jaimebm1229
                                    @paradadf said in Thanks again 🙂
                                    • Jaimebm1229
                                      Jaimebm1229 @Ricardo Dicky last edited by Jaimebm1229
                                      @ricardo-d**ky
                                      I did a clean install of recalbox
                                      Use the putty program to stop recalbox
                                      IP: ***
                                      Login: root
                                      Password: recalboxroot
                                      Stop or start Emulationstation
                                      /etc/init.d/S31emulationstation stop
                                      then enter
                                      mount -o remount, rw /
                                      then run WinSCP
                                      IP: ***
                                      Login: root
                                      get on the route
                                      /recalbox/share_init/system/.emulationstation
                                      and extract to the PC es_systems.cfg
                                      create the systems you want to add
                                      and copy it on this route
                                      /recalbox/share/system/.emulationstation
                                      last since putty starts recalbox
                                      Start start Emulationstation
                                      /etc/init.d/S31emulationstation start
                                      Possibly this badly written since I use the translator 😞
                                      Ricardo Dicky 1 Reply Last reply Reply Quote 0
                                      • Ricardo Dicky
                                        @jaimebm1229 thx man... 😉
