    SSH says "connection refused" since recalbox 6.0
    ssh connection refused connect
    • elbino
      elbino last edited by elbino
      Hey there,
      hope somebody here can help me. I just installed Recalbox 6.0 on my SD card and so far everything works fine except for the ssh connect from my Mac. Whenever I try to execute "ssh root@recalbox" it says: "connection refused".
      What I checked so far:
      • empty file ssh in /boot exists
      • should not be a network issue because I can access the web interface and have the file share as well
      • the option "system.ssh.enabled=1" is set correctly in recalbox.conf
      • message log says: Service "RECALBOX" (/etc/avahi/services/ssh.service) successfully established. --> looks fine
      With the last Recalbox version the ssh connect worked fine, so no problem with any firewall/whatever. Any idea what the problem could be and how to solve it?
      Thanks & best regards,
      Thomas
      dstroy 1 Reply Last reply Reply Quote 3
      • dstroy
        dstroy @elbino last edited by
        @elbino try ssh -v root@recalbox to have some information and paste the result of the command, are you using key authentification or password ?
        • elbino
          @dstroy: With param -v it just says:
          OpenSSH_7.9p1, LibreSSL 2.7.3
          debug1: Reading configuration data /etc/ssh/ssh_config
          debug1: /etc/ssh/ssh_config line 48: Applying options for *
          debug1: Connecting to recalbox port 22.
          ssh: connect to host recalbox port 22: Connection refused
          And I'm using the default authentication with user/password. No advanced security stuff activation.
          • Shira
            Shira last edited by
            Same issue, it always worked for me until 6.x, now it always says connection refused. I can ping the Pi fine from commandline, so the network does work.
              OyyoDams Staff @Shira last edited by
              @shira please open a new topic
              101.4k
