    [Recalbox 6.0+] ALEKFULL V1
    Themes & Interface
    theme alekfull recalbox 6.0 dragonblaze
    10
    19
    22380
    • fagnerpc
      fagnerpc Theme moderator last edited by mYSt
      Hi guys 🙂
      I updated the first ALEKFULL V1 theme to Recalbox 6.0 (Dragonblaze) - with new arts, logos and options 🙂
      Arts in 2 resolutions (1080p/ 720p)
      Are there many systems and the theme is getting too heavy?
      Use the 720p resolution for greater fluidity. Access the Main Menu, then go to UI Options, Theme Configuration, and System View Theme.
      Recommended also to run the Recalbox in 720p (which greatly improves the quality of the arts and performance of Raspberry Pi).
      Amiga
      PRBOOM
      Region Option and Two System Views
      Each resolution has 2 system views: carrousel wheel and carrousel vertical.
      The carousel code has been updated for a cleaner view - no logos overlapping others 🙂
      Another update is the region selection. With 3 region options (EU, US, JP) - your choice reflects on the arts and logos of the systems - EX: (NES on Japan is Famicom, PC Engine on USA is TurboGrafx 16)
      alt text
      alt text
      Compatible with all systems supported on Recalbox 6.0
      All systems supported in stable version 6.0 are available in the theme - with individual music, art and logos.
      alt text
      oopsss
      alt text
      alt text
      alt text
      • RECALBOX compatible with the update 6.0 DRAGONBLAZE and update 18.03.16 onwards;
      • Compatible with all Recalbox systems - including recent ones like Naomi and Amiga CDTV and custom systems.
      Available here
      ARCADE ALEKFULL
      1 Reply Last reply Reply Quote 9
      • PilafSama
        PilafSama last edited by
        Awsome, thank you fagner
        • bleep
          bleep last edited by
          Thanks fagnerpc it's beautiful 🙂
          • guiltybear
            guiltybear last edited by
            thanks for your theme alekfull i take it ! thanks for the community !
            • Roustouti
              Roustouti last edited by
              magnifique !! merci !!
              • mac33230
                mac33230 last edited by
                bonjour a tous sur recalbox 6 pc64 marche pas !
                • littlekan18
                  littlekan18 last edited by
                  Salut. Comment on fait pour changer les musiques s'il vous plait?
                  • Roustouti
                    Pour changer les ziks, repertoire system/.emulstation/themes/alekfull v1/assets/sound/ Tu as les fichiers en ogg.
                    • gaian
                      gaian last edited by
                      Le système plante quand je vais trop vite dans le menu. Après être sortie d’un Jeux. Recalbox 6.0 rasbery pi ...
                      SquierPsY84 1 Reply Last reply Reply Quote 0
                      • SquierPsY84
                        SquierPsY84 @gaian last edited by
                        @gaian salut ,met le en 720 p ça ne plantera pas
                        gaian 1 Reply Last reply Reply Quote 0
                        • gaian
                          gaian @SquierPsY84 last edited by
                          @squierpsy84 comment on fait ? J’ai mis la roulette en 720p mais les photos ?
                          • SquierPsY84
                            @gaian ça devrai pas planter ,normalement tu as image si tu as scraper tes jeux!,pi3 b+ moi ça plante pas,si je met en 1080 oui ça ralentira et j aurai des images blanches
                            • gaian
                              @squierpsy84 bah les images apparaissent plus un fond blanc a la place du coup il faut que je rentre dans un jeux pour que ça revienne
                              • SquierPsY84
                                @gaian ok ,t as quoi comme pi3? Du coup ça tire trop de jus (pi3b+ c bon,j ai essayer avec un pi3b c vrai y aura des images blanches car ça met plus longtemps à charger) mais normalement pi3b+ et mettre 720 et non 1080 p ,tout passe aucune image blanche
                                • gaian
                                  @squierpsy84 un 3b je pense mixer le thème ^^
                                  • gaian
                                    J’aimerais savoir où se trouvent les images 720p ?
                                    Pseudopode 1 Reply Last reply Reply Quote 0
                                    • Pseudopode
                                      Pseudopode @gaian last edited by
                                      @gaian tu as un dossiers assets dans l'archive, c'est là que sont situées les images.
                                      • gaian
                                        gaian @Pseudopode last edited by
                                        @pseudopode merci j’ai vu mais rien a faire le thème but toujours sur 2 ou 3 fonds
                                        • gaian
                                          Je retente avec ce thème quand on met weel 720p ça met aussi les images ? Car j’ai vu dans le dossier asset les images 720p
