    8Bitdo M30 Bluetooth - Connection Problems
    GamePad/GPIO/USB encoder
    8bitdo m30
    4025
    • murmelbahn
      murmelbahn last edited by
      Hello everyone,
      today my shiny new M30 8bitdo Pad arrived but I don’t get it working with Recalbox. The first thing I did was to update it to firmware 1.10. After this i try to pair it via bluetooth but sadly it didnt connect with my Pi 3b+ 😞 I’ve try it with the „normal“ mode and with the Switch mode activated but both didnt work.
      My Recalbox Version is the latest and in the Changelog they mentioned the M30.
      Does someone else have these problems?
      • Matth23
        Matth23 last edited by
        @murmelbahn said in 8Bitdo M30 Bluetooth - Connection Problems:
        Hello everyone,
        Hello, I have the M30 controller and I did not have a connection problem.
        Try to connect your controller manually : https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-manually-(EN)
        My only problem concern is latency.
        Thanks for your return.
        Version : 8.1.1
        Material : Raspberry Pi 3B+ / SanDisk 16Go
        Pads : 8BitDo SF30 Pro / 8BitDo M30 / Sony DualShock 3
        Box : Megapi Case
        • murmelbahn
          Okay I will try this. Did you also pair yours manualy or did you use the onscreen wizard?
          • Matth23
            I use the onscreen wizard but with RC2 Version, I have paired manualy.
            Version : 8.1.1
            Box : Megapi Case
            • bigbutler
              bigbutler last edited by
              I have 8Biotdo M30 and Pair in Switch mode and have not any issuses or lags works very fine on RPI3b+ Recalbox 6.0
              My System:
              RPI3b+ oc 1,5ghz FLIRC 2.0 Custom Design
              Recalbox 6.0 DragonBlaze
              My Controllers:
              PS3,PS4, Switch Pro, 8Bitdo SF30 Pro, 8Bitdo M30, Fighting Stick V2 Sanwa mod
              • Bkg2k
                Bkg2k Staff last edited by
                https://forum.recalbox.com/topic/17312/bluetooth-testers-wanted
