    Reaclbox 6.0 : sharedevice=NETWORK doesn't work
    reaclbox 6.0 doesnt
    2042
    • Hartigan
      Hartigan last edited by
      Hi every one !!! and thank you for all your work, it's so amazing.
      I've made the update to 6.0 version of the recalbox and all my roms are on a shared disk on my network. And the link doesn't work any more since the update. I have copied the line in recalbox.conf to set it up, but nothing happend (sharedevice=NETWORK
      sharenetwork_smb1=ROMS@192.168.X.XX:romrecalbox:username=XXXXpassword=XXXX). Have I made something wrong or is there somthing new to do ?
      skankster 1 Reply Last reply Reply Quote 0
      • Bkg2k
        Bkg2k Staff last edited by
        https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)#smb-v2-or-higher-support
        • skankster
          skankster @Hartigan last edited by
          @hartigan Hey Hartigan, same thing here. Did you find a solution? Bkg2k solution worked for you?
          • skankster
            skankster @skankster last edited by
            @skankster said in Reaclbox 6.0 : sharedevice=NETWORK doesn't work:
            Just to inform that got it working adding the "vers=1.0" thing at the end of the lines.
            • Hartigan
              Not try yet, i will see my configuration again and come back soon
              • Hartigan
                @skankster In fact, now i've got to specify the version of SMB. I've set-up to version 3 et set my NAS to version minimum 2 to maximum 3. thank you @skankster
