    Problems with SHADERS in Recalbox 6.0
    shaders recalbox 6.0
    • xHardcore
      xHardcore last edited by
      Hello, why do not I save the shader that I choose in the core? I get the following message "error saving shader preset". I always want to play with the same shader when I start playing. Thank you
        Because you need to add manually in recalbox.conf
        xHardcore 1 Reply Last reply Reply Quote 0
        • xHardcore
          xHardcore @acris last edited by
          @acris thanks for the answer, even putting manual, it gives error
          snes.shaders=/recalbox/share/shaders/shaders_glsl/mysnesshader.gplsp
          • nayok
            nayok last edited by
            @xHardcore I think this should be written like this :
            snes.shaders= "/recalbox/share/shaders/shaders_glsl/mysnesshader.gplsp"
            Rpi 3 B+
            Recalbox 9.1
            Usb Storage
            USB Xin-Mo controller
            • tekkenism
              tekkenism last edited by
              It's really a disturbing problem, having shaders not saved, setting them again and again on each game play. 😕
