    the keyboard is not working!
    keyboard wont work
    3853
    • Aggarti
      Aggarti last edited by Aggarti
      Hail!
      Put Recalbox 6.0 RC3 PC 64 bits. After loading, the keyboard does not work properly. The menu can only be accessed via "A", Enter works as a menu call, esc does not work. After changing the settings, language, etc., reboot - only the cursor keys work. It is treated only by re-filling the image. Tried ps/2 and usb.
      P.S. Put on RP3+ - the same crap.
        OyyoDams Staff @Aggarti last edited by
        @aggarti hey, did you read the manual ? The keyboard just works as expected!
        • Aggarti
          @oyyodams said in The keyboard won't work!:
          so this is normal?
            paradadf Staff @Aggarti last edited by
            @aggarti read the manual, please.
            https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#keyboardmapping
            Aggarti 1 Reply Last reply Reply Quote 0
            • Aggarti
              Aggarti @paradadf last edited by
              @paradadf After changing the interface language to "Russian", only the cursor keys work.
                paradadf Staff @Aggarti last edited by paradadf
                @aggarti spacebar doesn’t work? And the letters which are in the place of A and S in a QUERTY keyboard?
                And please, mind your language.
                • Aggarti
                  @paradadf said in the keyboard is not working!:
                  Space, enter, cursor keys work. A,S - no. Keyboard QWERTY.
                  P.S. Sorry - features of machine translation:)
