    i need help i cant see my recalbox on my network?????
    need help cant recalbox network
    6
    6
    1949
    • retrogamer23
      retrogamer23 last edited by
      i have tried directly plugging it into the router and nothing but it was working fine yesterday i dont know what i did wrong??????????? help!!!!
      Zing Bardamuz voljega 3 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @retrogamer23 last edited by
        @retrogamer23 Use the WInSCP program to find the recalbox on the network.
        • Bardamuz
          Bardamuz @retrogamer23 last edited by
          @retrogamer23 , if you have change the connection like Wifi > Lan , you must change the SSH setting using : CMD/Terminal , if you haven't try to restart the computer, time to time mine do that and after restart all work like a charm
          Same player shoot again
            voljega Banned @retrogamer23 last edited by
            @retrogamer23 might also be windows 10 samba security parameters
              Win 120 - Access network
              • couleurtroyes
                couleurtroyes last edited by
                windows icon + r ---- //RECALBOX and enter
