    Too much problems with last build
    too much last build
    2005
    • Cristian Muñoz
      Cristian Muñoz last edited by Cristian Muñoz
      I downloaded the last build 18.07.13 i installed with etcher. First it have only one "Theme". Th classic side scrolling theme is gone?. Second the scrapper doesn't work? i tried to scrap neogeo, cps, and mame and doesn't "find" anything.
      Last this build has kodi 16? what happened to kodi 17? Kodi 16 doesn't recognize bluetooth controllers. In fact doesn't recognize usb controllers at all.
      I don't know if im doing something wrong. I don't know which version i have before but it works fine, almost perfect 😞
        @cristian-muñoz Hello!
        About the themes: you can download several different themes and choose what you prefer, or you can even assemble your theme, this is not a big problem. The current themes have several types of preview, just go in the settings you will find other scrolling options. Link to download themes:
        https://forum.recalbox.com/category/14/themes-interface
        About Scrapper: It really is in trouble, but it's not Recalbox's fault, but rather from sites that previously allowed scrappers that have undergone changes and limitations, an alternative option is you use external tools, I recommend ARRM:
        https://forum.recalbox.com/topic/11850/arrm-another-recalbox-roms-manager
        About Kodi: In the next update we probably already have Kodi 17, but kodi is not the main focus of the team. Link to the open beta version with kodi 17:
        https://forum.recalbox.com/topic/15010/testers-wanted-major-system-upgrade-pi3b-kodi-17-and-much-more
        About kodi not recognize Bluetooth joystick: probably if you remake the basic mapping of the joystick, you'll already be able to use it in kodi.
        • Cristian Muñoz
          Ok i gonna try everything you told me XD. But one thing i not understand. How do i remake de mapping? i mean i already config the controller on the recalbox options, then when i launch Kodi the controller doesn't work. I missing something?
            Zing Global moderator Translator @Cristian Muñoz last edited by
            @cristian-muñoz Maybe, I do not know what your joystick, I can not say anything ... Describe as much information as possible: the hardware you are using (rpi0,1,2,3,3 + / pc32,64?), the joystick model , and what have you done to try to work, so I or someone else can help you
            • Cristian Muñoz
              Im using RPI3. Controlles ps3 shawan. I run recalbox, the system found the controller y map the entire controller, then i set the controller 1 default as shawan.
              I disconnect the controller and it work fine via bletooth. I play whatever no problems.
              Then with the controller i run Kodi. And stop working. I have to connect a usb keyboard to navigate to Kodi, even for shutdown.
                @cristian-muñoz Okay, so you're telling, you have the joystick's mapping properly, but have you tried REDO this mapping after discovering that is not working in Kodi?
                Also, you seted this control to player 1, but, have you tried to leave player 1 as automatic, and enter the kodi, to see if it works?
                Another possibility: you claim that your joystick is a ps3 shawan, did you even try to change the driver in the recalbox.conf file? Enter the file "recalbox.conf" and search for "controllers.ps3.driver", there are 3 possible drivers, and 2 of them claim to work on shanwan joysticks, my file for example is like "controllers.ps3.driver = bluez", but can be changed to "controllers.ps3.driver = shanwan".
