    Which recalbox emulators support zipped roms?
    recalbox zipped roms
    • MarcDK
      MarcDK last edited by
      Hi,
      I know that mega drive and nes seems to work. Is there a list? And does anybody know a command on the terminal to zip all roms with the same name and then delete the source?
      Thanks!
      https://marc.tv
        Hello
        Read in each roms folders : readme.txt
        MarcDK 1 Reply Last reply Reply Quote 1
        • tonificante
          tonificante last edited by
          @marcdk said in Which recalbox emulators support zipped roms?:
          You can search it by yourself: http://lmgtfy.com/?q=batch+file+script+to+zip+files+and+delete
          • MarcDK
            MarcDK @acris last edited by
            @acris
            Ok. Thanks. What about a page in the wiki with consolidated information?
            https://marc.tv
              paradadf Staff @MarcDK last edited by
              @marcdk you don’t need permission to create it, just do it 😉
