    Unsolved Burn Recalbox to External SD Card
    recalbox external card
    2746
    • rebecca
      rebecca last edited by
      I am new to PI and want to give a try on Recalbox. My question is how to burn the Recalbox OS to SD card?
        Hello @rebecca
        Look video tutorial
        Enable subtitle
        https://youtu.be/hl59A3FTK-U
        rebecca 1 Reply Last reply Reply Quote 1
        • rebecca
          rebecca @acris last edited by
          @acris said in Burn Recalbox to External SD Card:
          Hello @rebecca
          Look video tutorial
          Enable subtitle
          thanks. will check it out
          • uoaser
            uoaser last edited by
            This is a very challenging task for the novice ,the video tutorial doesn't do much good , why not get a tool to do ? It's more useful than video tutorial.
              Etcher is the tool.
                RUFUS also works, and if you're using windows, win32-disk-imager also works.
                @uoaser
                It is not so complex to install the recalbox on an SD card, moreover, with a simple search it is possible to find several videos on youtube explaining step by step, each one of its shape. If you are having difficulty, it is easier to search a little better, and find the video you prefer, there is no way to explain individually, for each newbie, with the way he prefers, without even knowing how much knowledge one has. ..
                The Forum exists to help, to exchange information, but we can not do everything than everyone wants, at the way they want, with the speed they want. Nor does it make sense to re-explain the same thing several times just because some newbie prefers to ask what they already have explained, than to try on its own.
                I do not want to offend, but do not be "lazy", search, try, and try again, if you really have problems, ask and someone will try to help.
                • uoaser
                  uoaser last edited by uoaser
                  This is what my teacher recommended , which can burn iOS file to USB/DVD/CD.
                  And you can use it to burn your Recalbox, do that like this : https://www.passmoz.com/burn-iso-image-to-usb-in-3-ways.html
