    Default keyboard shortcut for hotkey?
    default keyboard shortcut hotkey
    • ivwshane
      ivwshane last edited by
      Sometimes I only use a keyboard (especially for testing) but when in a game  I need to check some emulation settings. What is the default hot key when using only a keyboard?
      • digitaLumberjack
        There is none. Keyboard is not officially supported. You can configure it in the retroarch menu. To access retroarch menu, you should specify a custom configuration file for your emulators in recalbox.conf with no hotkey
        • Manuel Giuseppe Trizzo
          Manuel Giuseppe Trizzo last edited by
          I'm not practical, how do I make saving a game?
            paradadf Staff last edited by
            Don't use an old thread to make questions. Open your own one, please.
            And read the manual:
            https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)
              With your gamepad. Please read notice.
              There are a lot of combo hotkeys.
              101.4k
