    Gamecon and Powerbutton use the same GPIOs
    gamecon powerbutton same gpios
    • TeKo
      TeKo last edited by
      Gamecon controllers and the power and reset buttons seem to use the same GPIO (2 and 3)
      Is it possible to change the GPIO?
        Substring @TeKo last edited by
        @teko power scripts use GPIO 3-5-6 ( pin number). You may eventually change them if you need to
        TeKo 1 Reply Last reply Reply Quote 0
        • TeKo
          TeKo @Substring last edited by
          @substring So in a later version it will be possible to change the Pins?
          I could just not use the reset button, but it seems like the Power LED only works with Switch+Reset mode.
            @teko whatever you expect, GPIO can't be shared or you'll face some serious malfunction. 1 GPIO pin should be used for only a single purpose : arcade button, led, reset or power. With the configurable mk_arcade, you must remove as many arcade buttons as "side use" you'd wish.if you want power + reset + led, that's 3 gpio ... 3 less arcade buttons, not sure it's a good idea
