    Setting TAB key in Mame
    Emulator Arcade/PC/Console
    setzing tab key mame
    4768
    • Antonia
      Antonia last edited by Antonia
      Hi!
      Simple question:
      Recalbox current image is installed new, put roms to fba_libretro.
      They start fine, ESC key works, but how to set the TAB key to enter the mame settings?
      That's important, then all the keys (wich are totally wrong in default) can be set.
      btw: I have access to all partitions and files to modify them manually..
        paradadf Staff @Antonia last edited by
        @antonia fba isn‘t mame. On fba_libretro you can get the retroarch menu by pressing HK+B.
        • Antonia
          I know, but where to set the TAB button?
          I see many settings but not the default keys.
          Don't misunderstand me, I'm sitting here now about this simple problem since 7 HOURS! Most of it to get Hotkey + B working somehow (its a official Recalbax image from today)
          I work with emulators since 20 years, so I would say I'm not stupid. I call it TAB because its the key for the mame settings since the beginning...
            @antonia only mame has that TAB menu... that‘s what I tried to make clear.
            • Italo José Zomer
              Italo José Zomer last edited by
              I have the same problem. I use an arcade control to operate Recalbox, most of the emulators the access to it's menus is pressing Hotkey (in my case "Selecet) + B. My P1 control have 8 buttons, like a SNES control. B, A, X, Y, R, L, SELECT, START. How to set this "TAB" or "R2" button different?
                You need to use keyboard ou use virtualgamepad with smartphone
                Italo José Zomer 1 Reply Last reply Reply Quote 0
                • Italo José Zomer
                  Italo José Zomer @acris last edited by
                  @acris I tried with a keyboard but it isn't working inside the ROM, only in the menu. The only functions that are working using my 8 button game pad are:
                  Hotkey + Start = Exit the game
                  Hotkey + Y = Opens a window to choose a slot to save, but didn't show any slot option.
                  Hotkey + X = Opens a window to choose a slot to load, w/ the same problem of the saving.
                  Hotkey + A = Reset the game
                  I'm trying it in Mortal Kombat I (Mame version).
