    Recalbox 18.07.13 is out!
    Announcements
    recalbox 18.07.13 out
    24
    59
    66903
      Time was missinf for the blog post ... This is mainly a fix release :
      • B*mp desmume to desmume2015
      • fix: SELECT as hotkey sometimes messy with arcade
      • ES: Arcade roms fullname in Netplay GUID
      • ES: No game launch if core doesn't match
      • ES: Game not listed in lobby if password protected
      • ES: remove netplay popup to prevent some crash
      • Wifi: options were not saved with nfs cifs or configurations - fixed
      • Daphne: joystick improvements / bug corrections
      • N64 rice: fix blank screen
      • N64 GlideN64 and other plugins: also fix blank screen
      • pifba: make sure it's only available for systems supporting it
      • Set the recalbox tag for netplay elsewhere
      darth 1 Reply Last reply Reply Quote 8
      • darth
        darth @Substring last edited by
        @substring said in Recalbox 18.07.13 is out!:
        Hi, I have a raspberry pi 3B, I played a Nintendo 64 game and worked perfect, but when I went back to the menu and selected to play another N64 game, it got hang in a black screen.
        1 Reply Last reply Reply Quote 5
        • darkanezi
          darkanezi last edited by
          Hello! I've updated the system with the last 18.07.13 update and now my N64 roms stopped working. I was using mupen64plus + Gliden64 which worked perfectly before.
          If I change it to Libretto+Glupen64 it works, but the quality of this combination is terrible. Any hints or configs that I could do to fix that?
          Thanks a million in advance!
          • Francis Labo
            Francis Labo last edited by
            Made the update on my pi3b and it crashed. Message of emulation station error try manually.. what can i do ?
            rizzie 1 Reply Last reply Reply Quote 0
            • Juan Daniel
              Juan Daniel last edited by Juan Daniel
              Good afternoon,
              I can´t update either. When the download ends, Recalbox starts to reboot, the progress bar appears only for a second. After that Recablox reboots again and it starts normally. A popup appears again to say me that there is an update available.
              I see this in the log:
              [ 421.35] ------------ Will process to the recalbox upgrade from https://lb-archive-prod.recalbox.com ------------
              [ 421.37] Need 261432375
              [ 421.40] Needed size for upgrade : 255305kb
              [ 421.42] Will download 255305kb of files in /recalbox/share/system/upgrade where 18608772kb is available. Free disk space after operation : 18353467kb
              [ 421.44] https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/boot.tar.xz downloaded
              [ 421.47] https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/root.tar.xz downloaded
              [ 421.50] https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/boot.tar.xz.sha1 downloaded
              [ 421.52] https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/root.tar.xz.sha1 downloaded
              [ 421.55] https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/root.list downloaded
              [ 421.58] boot.tar.xz checksum verified
              [ 421.60] root.tar.xz checksum verified
              [ 421.63] All files downloaded and checked, ready for upgrade on next reboot
              [ 425.72] Stopping S94manager
              [ 426.04] Stopping S92switch
              [ 426.06] script /recalbox/scripts/powerswitch.sh already stopped !
              [ 426.98] Stopping Emulationstation
              [ 427.06] Saving ALSA mixers configuration
              [ 427.38] Stopping S13fbcp
              [ 428.03] recalbox.conf saved to /boot partition
              [ 1.63] Let's play the video for 20 seconds
              [ 3.21] /boot/recalbox-backup.conf not found
              [ 5.07] Restoring sound config before reboot
              [ 5.13] Upgrading RA Core names
              [ 12.83] Stopping S94manager
              [ 13.06] Stopping S92switch
              [ 13.07] script /recalbox/scripts/powerswitch.sh already stopped !
              [ 13.70] Stopping Emulationstation
              [ 13.77] Saving ALSA mixers configuration
              [ 14.05] Stopping S13fbcp
              [ 14.59] recalbox.conf saved to /boot partition
              [ 3.07] /boot/recalbox-backup.conf not found
              [ 3.84] No need to upgrade configuration files
              [ 4.23] Will not start S13fbcp : system.fbcp.enabled is set to 0
              [ 4.58] starting new log
              [ 4.60] converting dos to unix carriage return characters
              [ 4.99] setting hostname to RECALBOX
              [ 5.13] setting audio volume to 26
              [ 5.14] setting timezone to Europe/Madrid
              [ 5.17] updated wifi settings : ssid=
              [ 5.27] ---- recalbox-config.sh ----
              [ 5.32] setting audio volume : 26
              [ 5.33] setting keyboard layout to es
              [ 5.34] updated wifi settings : ssid=
              [ 5.49] Simple mixer control 'PCM',0
              [ 5.50] Capabilities: pvolume pvolume-joined pswitch pswitch-joined
              [ 5.50] updated wifi settings : ssid=Mi~FibraC04B
              [ 5.51] Setting volume for numid=3
              [ 5.52] Playback channels: Mono
              [ 5.53] Limits: Playback -10239 - 400
              [ 5.54] Setting volume for numid=2
              [ 5.55] Mono: Playback 0 [96%] [0.00dB] [on]
              [ 5.57] Setting volume for numid=1
              [ 5.59] Setting volume for numid=5
              [ 5.62] amixer: Control default element write error: Operation not permitted
              [ 5.62] Setting volume for numid=4
              [ 5.63]
              [ 5.65] Restoring ALSA mixers configuration
              [ 5.81] setting audio to hdmi
              [ 5.84] ---- recalbox-config.sh ----
              [ 5.87] setting audio output mode : hdmi
              [ 5.89] numid=3,iface=MIXER,name='PCM Playback Route'
              [ 5.90] ; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
              [ 5.92] : values=2
              [ 6.33] starting emulationstation with lang = es_ES
              [ 7.27] ---- recalbox-config.sh ----
              [ 10.51] Starting S92switch
              [ 10.54] script /recalbox/scripts/powerswitch.sh [ STARTED ]
              [ 11.66] Starting S94manager
              [ 11.82] ... Starting manager v2
              [ 12.07] Will not start pm2 : system.api.enabled is set to 0
              [ 14.22] starting xarcade2jstick
              [ 14.57] xarcade2jstick : no official stick found, looking for keyboard encoder now ...
              Kind regards and thanks for Recalbox. 🙂
              • Moritz
                Moritz last edited by
                I was playing with friends using password to prevent other players join and lag the game, now I can't join the host anymore because the game don't show in lobby, will we be able to create private games?
                paradadf Substring joinski 3 Replies Last reply Reply Quote 0
                  paradadf Staff @Moritz last edited by
                  @moritz not over ES... you‘ll need to join over retroarch menu directly.
                    Substring @Moritz last edited by
                    @moritz as long as retroarch doesn't give a solution to easily handle passwords, then you must join through RA
                      Substring @Juan Daniel last edited by
                      @juan-daniel please check logs in the upgrade folder
                      Juan Daniel 1 Reply Last reply Reply Quote 0
                      • Juan Daniel
                        Juan Daniel @Substring last edited by
                        Hi @substring,
                        upgrade.out.log
                        Tue Jan 1 01:00:02 UTC 1980
                        Upgrading /boot
                        Tue Jan 1 01:00:03 UTC 1980
                        Upgrading /
                        upgrade.err.log
                        mount: mounting /dev/root on / failed: Invalid argument
                          @juan-daniel Can you make a support archive please ?
                          • Juan Daniel
                            @substring Yes, of course. Thanks!
                            Support file
                              @juan-daniel Do I correctly assume you've installed recalbox though NOOBS ?
                              • Juan Daniel
                                @substring No, I downloaded the ISO from Recalbox website a long time ago (before than version 4.0), and I have been updated until now.
                                If it will take you a lot of time, I can download a clean version from the website and set the games and savegames, it´s not a problem. 🙂
                                Thank you and kind regards.
                                • glook
                                  glook last edited by
                                  100 000 000 de mercis à la team pour le travail tout en finesse (la legende du bouton X qui change si on a activé netplay/kofi ou l'un des deux, le temps de chargement, les ptits trucs à droite à gauche...) et pour Daphné !!! j'ai enfin passé quelques niveauxà Dragon's Lair, EN VRAI, j'ai limite la larme à l'oeil...
                                  QUE DU BONHEUR ! MERCI !
                                  GlOoK
                                    Substring @glook last edited by
                                    @glook quel sens de l'observation 😉
                                    • Dotto Raus
                                      Dotto Raus last edited by
                                      "Insert coin button is not working" in Mame games so they are impossible to play even using key "5" of my keyboard. Fba and Fba lbretro games seems to be ok and the "select" is working.
                                      I thought with 13.07.18 update that issue was solved infact it was coming out with the previous upgrade but nothing.
                                      Maybe i've done something wrong, can you help me please?
                                      Dotto Raus 1 Reply Last reply Reply Quote 0
                                      • RCP
                                        RCP last edited by
                                        Para as minhas roms , a atualização funcionou bem com exceção ao fba. Então peguei outro cartão e queimei uma imagem limpa e para minha surpresa as roms que continuaram rodando no cartão atualizado não funcionam com a instalação à partir do zero. ( fds / dreamcast / sega cd / pcengine cd / msx / amiga600 / amiga1200 / odyssey / colecovision) . Já baixei novamente a imagem à partir do site e refiz a instalação mas essas roms continuam não funcionando, alguma dica de como proceder ? muito obrigado.
                                        • Scorpio70
                                          Scorpio70 last edited by
                                          Merci à toute la team pour ce super boulot
                                          • Gimpi
                                            Gimpi last edited by
                                            nice thx for the update 😄
                                            is it just me or are the input lag are minimized now ?
                                            freaking work will donate as soon as possible thy @Substring
