    Transfer roms to internal storage via USB and How to reset to default settings
    transfer roms internal storage usb
    • Sylvester
      Sylvester last edited by
      So I've been transfering roms via windows explorer or my web browser.
      But I never found out how to do it by just plugging it in a usb drive to the RPi and loading them that way.
      I know you can play games off the USB drive but I'd very much like to just transfer them over?
      Also,
      How do you go about doing a "reset to default settings"?
        paradadf Staff @Sylvester last edited by
        @sylvester the wiki is meant to be read, the search function to be used.
        https://github.com/recalbox/recalbox-os/wiki/Copy-roms-from-a-Computer-to-the-SD-Card-using-an-USB-Stick-(or-External-Hard-Drive)-(EN)
        You can use the file manager from Kodi to transfer them with a UI too.
        There is no "reset to defaults" in recalbox... Just reinstalling.
          Substring @paradadf last edited by
          @paradadf if he meant "unload the roms from the usb key to the sd", then nope there is no easy way for that
