    V3.2.7 - versionning rush !
    v3.2.7 versionning rush
    8
    16
    4424
    • digitaLumberjack
      So much version in no time. The 3.2.6 corrected some 3.2.5 issues, the biggest one was the nfs startup script block the boot. It added the following too :
      • Added v64 extenson for n64
      • Added xbox360 wireless defaut configuration
      • Fixed : power management of ew-7811un
      • Added kodi mysql support
      The urgently sreleased 3.2.7 corrected kodi that did not boot because he couldn't find mysqlclient.so. https://github.com/digitalLumberjack/recalbox-os/releases/latest Now i need to know if the mysql nas work 😄
      • hstampfl
        hstampfl last edited by
        hi, shouldn't it be: Added v64 extenson for n64
        I started my retro passion in 1985 with my C64.....Today I have a small (retro) console collection including NES, SNES, N64, GC, Wii, WiiU, GB, GBC, GBA, NDS, DSi, 3DS, 3DS XL, 2DS, NEW 3DS, SMS, SMD, SG, SD, XBOX, XBOX360, XBOX ONE, PSone, PS2, PS3, PS4, PSP, PS VITA, VECTREX, C64, AMIGA 600, MIST Board, Turbo Chamäleon
        • tank
          tank last edited by
          oooh, now sql support too already! if kodi can change the tv refreshrate to 23,9hz, 24hz, 50hz,... if kodi can passthrough dts and ac3 if kodi and ES and retroarch support a nes30 gamepad and if i can mount smb-shares (roms and movies) THEN I'd be a very happy rpi-user/retrogamer thank you for your dedication to this, even though i didnt even install it yet to my new and unused rpi2 🙂
          • digitaLumberjack
            @hstampfl
            hi, shouldn’t it be: Added v64 extenson for n64
            This morning was too early, this evening it's too late.
            • james-lord
              james-lord last edited by
              Checking Mysql on the NAS - All seems well 🙂 GREAT work and thank you!
              if kodi can change the tv refreshrate to 23,9hz, 24hz, 50hz,… if kodi can passthrough dts and ac3
              It can 🙂
              • energizer
                energizer last edited by
                been updating for 10mins+ now, server overload?
                • A Former User
                  A Former User last edited by
                  Je viens de l'installer, tout fonctionne nickel. Prise en charge des clés usb en NTFS / FAT au top - Par contre toujours le soucis pour configurer la touche "R2" de la manette Xbox 360 - Toujours plantage ( obliger de retirer le câble d'alim ) quand je quitte KODI En tout cas tu as fait vraiment du bon taff 🙂 SUGGESTION : - Pourquoi ne pas rajouter "KODI" avec une image dans la bibliotheque de Emulationstation avec les consoles plutôt que dans le menu avec le bouton start ? - J'attend avec impatience la prise en charge de la manette Xbox dans Kodi
                  • energizer
                    what do you mean by that?
                    • digitaLumberjack
                      Added xbox360 wireless defaut configuration what do you mean by that?
                      The xbox 360 controller should be detected in emulationstation without having to configure it.
                      • energizer
                        oh ok, but still blinking right?
                        • digitaLumberjack
                          Yes, i add an option in recalbox.conf, but it will be for the 3.2.8...
                          • energizer
                            nice!
                            • benjio
                              benjio last edited by
                              This distro is awesome! I've been using 3.2.4 in an arcade cabinet using buttons on the gpio pins. 3.2.4 had a selector to enable gpio input, but it seems to be missing in the new release. I did a fresh install of the new version and my joysticks do not work anymore! I'll be using the older version for now. Thanks for the update! Kodi built-in was one of the reasons I chose your distro! Glad it's fixed.
                              • digitaLumberjack
                                Hi, Yes the GPIO switch has been removed from the menu, as it was not mainstream. You can now configure it in the recalbox.conf file. https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-(EN)
                                • imaster
                                  imaster last edited by
                                  – Par contre toujours le soucis pour configurer la touche « R2″ de la manette Xbox 360
                                  J'ai constaté également ce problème, j'ai une manette filaire de 360. Autre soucis je perds les données "scrappées" au redémarrage. Y a-t-il quelque chose à faire pour bien les sauvegarder? J'ajoute que je n'ai pas trouvé de clavier visuel pour entrer du texte à la manette (peut-etre qu'il n'y en a pas). Cela pourrait etre pratique car pour scrapper "manuellement" il faut modifier le nom du jeu. Merci
                                  • imaster
                                    Un petit retour pour dire que je crois avoir réussi tout de même à configurer la touche L2 en finissant la config et en reselectionnant cette touche dans le menu et cette fois l'appui sur la touche est pris en compte. A noté que j'ai aussi réussi à utiliser une manette de xbox originale (modèle slim) avec la modification (bien connue) pour ajouter un port USB et j'ai eu un problème similaire au L2 mais pour la touche R1 de mémoire.
