    Big Thanks to Recalbox team.Thank you for your hard work!
    Your recalbox
    big thanks recalbox team.thank hard
    2891
    • Andrei
      Andrei last edited by
      BIG THANKS TO RECALBOX TEAM !!!!!!!!!
      HYPERION PROJECT
      OyyoDams Substring 2 Replies Last reply Reply Quote 5
        OyyoDams Staff @Andrei last edited by
        @andrei awesome!
          Substring @Andrei last edited by
          @andrei Nice job ! is it me or you had to rotate the screen 180° ?
          • Andrei
            Yes, that was my 1st challenge.I didn't know that you can not see on that angle on LCD.Looks like if you rotate it you get a better view in small angles.
              @andrei rotating it may slow down the GPU, should check at the raspberry doc
              Andrei 1 Reply Last reply Reply Quote 0
              • Andrei
                Andrei @Substring last edited by
                @substring
                Maybe others are having the same problem so i will exemplify my reason.Looks like my monitor is not angle view 🙂
                Normal view
                Rotated 180
                Rotate view was the only solution beside changing the monitor.
                • cazeysan
                  cazeysan last edited by
                  Bravo for your work !
                  Viens par là, c'est pareil !
