    x64 system running 18.04.20 doesn't work too well
    x64 running 18.04.20 doesnt too
    14167
    • SylGaud
      SylGaud last edited by
      @Substring
      Hi, I'd like to add my experience with the GT 710 on this page: https://github.com/recalbox/recalbox-os/wiki/PC-compatibility-(EN)
      do I have to create an account, or use the pull request? (or simplier: I tell you my feedback and you paste it^^)
      Thanks
        voljega Banned @SylGaud last edited by
        @sylgaud it's just a wiki, you only need an account
        • SylGaud
          SylGaud @SylGaud last edited by SylGaud
          GT 710 isn't properly seen.
          I've tested Wii and GameCube with the GT 710 under Windows 10 --> perfectly smooth, filtered etc...
          So GT710 not yet compatible with RB.
            Substring @SylGaud last edited by
            @sylgaud what's the point of comparing windows and recalbox ???
            SylGaud 1 Reply Last reply Reply Quote 0
            • SylGaud
              SylGaud @Substring last edited by
              @substring
              I'm not comparing, I'm explaining how I came to say that GT710 is not properly handled by RB:
              • When launching dolphin, I can read up the screen that the GPU is correctly detected (yellow lines telling what GPU is detected, openGL etc..)
              • ES, dreamcast, N64 perfectly smooth and sharp.
              These 2 experiences let me think that GPU was correctly detected.
              But as I could see under windows, it is not .
              Indeed, wii and gamecube are waaayyyy smoother under Windows than RB.
              So no complaining or comparison, only some tests to get some more precise and final answers.
                @sylgaud how many GPU do you have on your setup ?
                • SylGaud
                  @substring
                  2: the integrated INTEL SANDYBRIDGE, and the PCI MSI GT 710
                  (... pretty obvious to say, but of course, when I plug the MSI in, I use the corresponding VGA port, and not the Intel's one...)
                  100.2k
