    Kodi outputs garbage
    kodi outputs garbage
    • Dm1
      Dm1 last edited by
      Kodi in Recalbox outputs garbage instead of video with hardware acceleration enabled on Raspberry Pi 3. In both Retropie and Batocera it's working perfectly on the same board.
      • Dm1
        Dm1 last edited by
        Hey. I have some more info about this issue. Usually I encounter it when I try to watch IPTV with Recalbox built-in Kodi, but as I've tested out it's not an IPTV related decoding issue, it depends on stream what Kodi is trying to decode with the help of hardware acceleration.
        I've captured the same stream into a file without reencoding and it still outputs garbage in Recalbox Kodi.
        Everyone can try and see the result:
        https://mega.nz/#!dJMnEaRJ!E0PPXE5hOqEmcv1MAVzh7Hk8kBdp-FWlmhdarH3Vd4E
        https://mega.nz/#!gIc0zITT!oeiwFyij433u7854FQYz9maEbzwgJ9r5T6nHU6pQPco
        https://mega.nz/#!VJ1CkYyI!Up3kzeQwcyOw7quR2gArNIXmLCI-8CRXEbqrn0NJ2Mk
        This doesn't happen in Kodi on other Raspberry OS distributions.
          OyyoDams Staff @Dm1 last edited by
          @dm1 Kodi will be updated soon with Recalbox, wait for this, it might fix your issue.
          Substring 1 Reply Last reply Reply Quote 1
            Substring @OyyoDams last edited by
            @oyyodams said in Kodi outputs garbage:
            soon
            Yeah, i.ve been saying this for 6 months ...
            • Dm1
              Dm1 last edited by
              Recalbox fork is using new version of Kodi for a while now and it's working good, fast and smooth there.
