    Solved Is there a way to make recalbox show rom actual filenames?
    Themes & Interface
    2589
    • horotony
      horotony last edited by
      I ask that cause it's kinda trouble to have two or more versions of the same game.
      Let's say I have Castlevania IV (U).smc, Castlevania IV (U) [T-por].smc and Castlevania IV [hack].smc;
      They all show the same name ("Castlevania IV"), with the same scraped cover, so I was trying to find a solution for that.
      Substring SuperMagicom 2 Replies Last reply Reply Quote 0
        Select game > select button > edit metadata > edit name
        horotony 1 Reply Last reply Reply Quote 0
          Substring @horotony last edited by
          @horotony ES automatically srips some parts of the name
          • horotony
            horotony @acris last edited by
            @acris Yeah I know that, I just want an easy way to do that don't involve me manually editing over 700 roms per system.
            @Substring I know that too =/
            • SuperMagicom
              SuperMagicom @horotony last edited by
              @horotony Re-scrape them with UXS and set it to use the filename in the gamelist.xml
              • horotony
                horotony @SuperMagicom last edited by
                @supermagicom Thanks! It worked flawlessly.
