    how to add new core in recabox?
    core recabox
    8
    25
    18260
    • Juliano Gonçalves Lima
      Juliano Gonçalves Lima last edited by
      I would like to add the core redream_libretro to the emulator of dreamcast I heard that this core is in constant improvement, I wanted to test it, the other core reicast_libretro seems to have been discontinued
      this core redream_libretro is already part of lakka!
      OyyoDams Gaetan gkralicek2 3 Replies Last reply Reply Quote 1
        OyyoDams Staff @Juliano Gonçalves Lima last edited by
        @juliano-gonçalves-lima Hi,
        That's not an easy task. If you want to add a core yourself, you have to make a buildroot package and crosscompil it. All is explained here: https://gitlab.com/recalbox/recalbox/wikis/home
        • Gaetan
          Gaetan Theme moderator @Juliano Gonçalves Lima last edited by
          @juliano-gonçalves-lima what enhencement coud it give ?
            Source code is no more available (and you have to pay if you want a binary) and libretro core is based in last public sources not updated since the fork...
            So constant improvements is maybe not the best expression.
            Anyway we will add it on x86_64 version in the next months, but not in arm boards that are not powerfully enough to use it.
            rockaddicted 1 Reply Last reply Reply Quote 2
              I'm sorry but I have no knowledge with programming, I believe I could never add this core, thank you very much I'm looking forward to this new version x86_64, who knows in the near future you do not create one for the raspberry pi
              • Gaetan
                Gaetan Theme moderator last edited by
                It's the second time today I read about this core. Seems to be promising. Apparently Lakka add it. I may give it a try and give my feedback here
                  thank you very much, if you need help testing some games you can talk to me
                  • BlockABoots
                    BlockABoots last edited by
                    @juliano-gonçalves-lima said in how to add new core in recabox?:
                    redream_libretro
                    Can you not just load a libretro core then once loaded go into the libretro core settings (usually your 'shortcut/function button' and 'Button B') then go to 'updater' then 'core' and download the redream_libretro from there?
                      voljega Banned @BlockABoots last edited by voljega
                      @blockaboots no you can't, it's recalbox, not retropie.
                      BlockABoots 1 Reply Last reply Reply Quote 0
                      • BlockABoots
                        BlockABoots @voljega last edited by BlockABoots
                        @voljega I though you can select what core to run for each emulator in the advanced emulator settings??
                        So say for example i load a MegaDrive game then go into RetroArch settings and update the Genesis GX Plus core it wont actually run the updated version on restart?
                        gkralicek2 1 Reply Last reply Reply Quote 0
                        • gkralicek2
                          gkralicek2 @BlockABoots last edited by
                          @blockaboots No it won't :=(. It will indeed download the updated version of the compiled *.so file but you will need to place it in the /usr/lib/libretro manually afterwards if you want it to be launched next time
                            voljega Banned @gkralicek2 last edited by
                            @gkralicek2 didn't even knew that was possible ...
                            • gkralicek2
                              gkralicek2 @voljega last edited by gkralicek2
                              @voljega When opening retroarch and selecting update core, it displays the content of https://buildbot.libretro.com/nightly/linux/armhf/latest/
                              A core can then be selected and downloaded but it's stored within retroarch folders and needs to be moved manually to the proper recalbox core folder afterwards.
                              I did it to update my mame2003 core with the latest version from 30/03 which eventually solved the annoying sound problem in mortal kombat 1 (the voice constantly shouting "finish him" in the character selection screen instead of pronouncing the character's name)
                              BlockABoots 1 Reply Last reply Reply Quote 1
                              • gkralicek2
                                gkralicek2 @Juliano Gonçalves Lima last edited by
                                @juliano-gonçalves-lima I tried the core redream_libretro through the Lakka distrib and it's super slow on a pi 3 even cranking the overclock to 1400 Mhz. When i get around 45-50 fps on soul calibur using reicast, i got only 15-20 using redream_libretro
                                This core is too "heavy" on CPU resouces for any Pi at the moment so there is really no point in integrating it in Recalbox so far.
                                Juliano Gonçalves Lima 1 Reply Last reply Reply Quote 0
                                  Armhf cores do not always work on recalbox 😉
                                  • gkralicek2
                                    gkralicek2 @Substring last edited by
                                    @substring Yes of course :=) ! But some of them work really well like for example the Quake emulator libretro_tyrquake which is not still officially integrated in recalbox (at least i think it's not but maybe i'm wrong)
                                      Substring @gkralicek2 last edited by
                                      @gkralicek2 it's not, and no reason to add it anyway. If we add 1 system per sibgle game core, themers will hate us
                                      • gkralicek2
                                        @substring i see :=)
                                          Juliano Gonçalves Lima @gkralicek2 last edited by
                                          @gkralicek2 hank you, for testing let's wait for a raspberry pi 4 who knows we can run more games!
                                            rockaddicted @rockaddicted last edited by
                                            @rockaddicted said in how to add new core in recabox?:
                                            No surprise. If I said that in my first post that is because I already tested this emulator and I know that it didn't include a dynarec.
