    Waveshare 7 inch screen
    waveshare inch
    3295
    • Greed
      Greed last edited by
      Re : Waveshare 7 Inch using Recalbox
      Hi Everyone,
      I've been reading several posts on these screens.
      I bought one and have entered the codelines that i found in this topic and also tried it with 1024 600 instead of 800 480
      https://forum.recalbox.com/topic/6088/waveshare-7-inch-using-recalbox/5
      So the recalbox interface is fine,
      but as soon as i open a rom on different emulators, i always have a left margin and an up small one...
      If i change the global.videomode to default then it doesn't fit the whole screen and having a 7inch screen is then useless
      When there is a margin, the global size of the image is much better.
      Any idea please ?
        Hello
        may be help https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        • Greed
          Thank you, do you kow where i can fin DMT resolutions list ?
          I'm affraid to have to configure each emulator separately T_T
          Wonder if 5 inch wouldn't be enough then...
          idarius 1 Reply Last reply Reply Quote 0
          • idarius
            idarius @Greed last edited by idarius
            @greed hi,
            list of DMT resolution : https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
            to configure your resolution for all emulator, your can use this line in the recalbox.conf :
            global.videomode=DMT XX HDMI
            dont forget to set your dmt number in the line instead of the XX.
            • Greed
              Wow great thank you for the list, going to try this as soon as i can, i'll give you an update if anything works correctly !
              • Greed
                Greed last edited by Greed
                Ok !
                So i've been trying a few settings now and the first "problem" of the screen is that it is a 16/9
                If i change the ratio and not the videomode the resulte is ok on many emulators except the dreamcast one.
                The dreamcast one doesn't center the image on his own.
                Do you know if there is a way to make a padding or something like that please ?
                Is there also a way to enter a custom resolution ?
                idarius Substring 2 Replies Last reply Reply Quote 0
                • idarius
                  @greed
                  you can try with hdmi cvt in the config.txt :
                  https://www.raspberrypi.org/forums/viewtopic.php?t=24679
                  something like this, with your own resolution :
                  hdmi_cvt=1920 240 60 1 1 0 0
                  info on numbers :
                  hdmi_cvt=<width> <height> <framerate> <aspect> <margins> <interlace> <rb>
                  width        width in pixels
                  height       height in pixels
                  framerate    framerate in Hz
                  aspect       aspect ratio 1=4:3, 2=14:9, 3=16:9, 4=5:4, 5=16:10, 6=15:9
                  margins      0=margins disabled, 1=margins enabled
                  interlace    0=progressive, 1=interlaced
                  rb           0=normal, 1=reduced blanking
                  and you need to setup the boot in this custom mode, in the config.txt :
                  hdmi_group=2
                  hdmi_mode=87
                  (custom mode is on mode 87)
                  in recalbox.conf, you should put
                  global.videomode=default
                  or
                  global.videomode=DMT 87 HDMI
                  I think the default should work.
                    Substring @Greed last edited by
                    @greed just set global.videomode=default, with the next release you should be able to reliably set it to auto
                    • Greed
                      Ok so i've been trying what idarius said.
                      I just let the aspect on 3 cause my screen is 16:9
                      For the dreamcast emulator and playstation (let's say next gen :p) it works perfectly great !
                      Better image scaling and centered !
                      For the rest it's ok, it's just that i think it's a too big screen to play retro games.
                      The only games who do not fit well on the screen are really old shoot'em up like 19XX
                      As i want to include my screen in a portable console (that will work like the switch console) i'll try a 5inch screen and give you an update if it's better if you are interested.
                      Thank you for all your informations !
