    Problem with recalbox on pi3 via NOOBS
    recalbox pi3
    7
    13
    8656
    • xristoskon
      xristoskon last edited by xristoskon
      I have just installed debian and recalbox , on pi 3 . As the debian boots correctly , recalbox doesnt boot at all and my monitor goes off while it boots , it means it gets no sygnal .
      What should i do
      Bellow my configs :
      recalbox-boot.conf:
      sharedevice=INTERNAL
      global.videomode=default
      config.txt:
      uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=1
      uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      comment to get jack audio
      #hdmi_drive=2
      Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      So manually enable audio
      dtparam=audio=on
      config_hdmi_boost=0
      force hdmi while the tv can take time before sending the signal on the hdmi output
      #hdmi_force_hotplug=1
      uncomment for composite PAL
      #sdtv_mode=2
      uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      uncomment if you don't want the rainbow at startup
      disable_splash=1
      Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      #avoid_safe_mode=1
      disable_overscan=0
      overscan_scale=1
      sdtv_mode=2
      hdmi_group=1
      hdmi_mode=16
      any suggestions ?
      Substring 1 Reply Last reply Reply Quote 1
        Substring @xristoskon last edited by
        @xristoskon have you tried our img ?
        • xristoskon
          no cause i want multi boot system , have u got an multi image ?
            @xristoskon nope
            • Anderson 72
              Anderson 72 last edited by
              @xristoskon said in Problem with recalbox on pi3 via NOOBS:
              What should i do
              Bellow my configs :
              recalbox-boot.conf:
              config.txt:
              #hdmi_safe=1
              disable_overscan=1
              #hdmi_group=1
              #hdmi_mode=1
              #hdmi_drive=2
              dtparam=audio=on
              config_hdmi_boost=0
              #sdtv_mode=2
              #dtoverlay=lirc-rpi
              boot_delay=3
              disable_splash=1
              Overclock
              gpu_mem_256=128
              gpu_mem_512=256
              gpu_mem_1024=512
              #avoid_safe_mode=1
              disable_overscan=0
              overscan_scale=1
              sdtv_mode=2
              hdmi_group=1
              hdmi_mode=16
              any suggestions ?
              I have some ploblem with my recalbox in multiboot.
                May be related to some newer pi3 boards, that's what the raspberry guy told me
                • maxmoro77
                  maxmoro77 last edited by
                  @Substring Also for me, Recalbox via NOOBS does not work at all! If I use your img file downloaded from here everything is fine!
                  But, if I use NOOBS to install RECALBOX with other o.s. (or even alone!) does not work !!
                  The result is a white (or sometimes gray) screen. I tried every possible combination of the config.txt file but with no result! I think the problem is in the same image of Recalbox for noobs ... 😢
                  I use Raspberry Pi 3 (not new B+ model obviously!).
                    Substring @maxmoro77 last edited by
                    @maxmoro77 i'm not sure how you installed recalbox with noobs, i haven't had any problem so far
                    maxmoro77 1 Reply Last reply Reply Quote 0
                    • lfer23
                      lfer23 last edited by
                      I have exactly the same issue. I had working triple boot with PINN, Libreelec, Recalbox and Raspbian. since last manual reinstall from PINN, I have Screen issue with the screen resolution. The OS seems to boot because there is sound from the HDMI but the resolution is out of range.
                      • maxmoro77
                        maxmoro77 @Substring last edited by
                        @substring I downloaded the last version of NOOBS (2.7.0) from raspberry site:
                        https://www.raspberrypi.org/downloads/noobs/
                        Recalbox is not compatible with this version of NOOBS.....
                        Now I found an old version (NOOBS 2.4.5) and whit this one all works fine....
                          @maxmoro77 raspberry told me they "disabled" recalbox until we're compatible with 3b+. This could be linked
                          • Juakin
                            Juakin last edited by
                            Exact same issue here...
                            • Dagui
                              Dagui last edited by
                              Had the same issue with the same dualboot, solved it with using the 2.4 version of Noobs.
                              Hey Ray, passe le flingue ! .................................OO Merci, Ray.
