    Recalbox Update 18.03.X - Data backup necessary?
    recalbox update 18.03.x data backup
    • korni
      korni last edited by
      Presumably, there will be an update on Friday (18.03.?16?) I have made some modifications to my current system. In particular, I have 2 Fantasy consoles integrated (Tic80 + Pico8). So this modifications affects the theme folder and the "es_systems.cfg".
      Will these modifications be deleted by the update?
      OyyoDams voljega Substring 3 Replies Last reply Reply Quote 0
        OyyoDams Staff @korni last edited by
        @korni all I can answer is... you should always backup your data, mostly if you have made custom modifications. It's a good advice in all cases, not only for Recalbox.
          voljega Banned @korni last edited by
          @korni said in Recalbox Update 18.03.X - Data backup necessary?:
          So I assume you did it by yourself ? any chance sharing the code ?
          korni 1 Reply Last reply Reply Quote 0
            Substring @korni last edited by
            @korni depends if you edited the share_init es_systems.cfg or another one. In the first case : do backup, it's erased at each upgrade
            • korni
              korni @voljega last edited by
              @voljega If my time allows it in the next few days, then I'll send you a message. 🙂
