    Wireless XBOX controller will not get detected.
    GamePad/GPIO/USB encoder
    wireless xbox detected
    7
    15
    5943
    • Elgur
      Elgur last edited by
      Hey guys!
      I'm new to recalbox, but so far it looks awesome!
      I've used RetroPie before but wanted to try RecalBox.
      My wireless XBox controllers doesn't get detected.
      How can I solve this?
      Thanks in advance!
        paradadf Staff @Elgur last edited by
        @elgur get a dongle.
        Elgur 1 Reply Last reply Reply Quote 0
        • Elgur
          Elgur @paradadf last edited by
          @paradadf said in Wireless XBOX controller will not get detected.:
          And then? I got one.
            voljega Banned @Elgur last edited by
            @elgur is it xbox 360 or xbox one ?
            • Elgur
              Elgur @voljega last edited by
              @voljega Xbox 360.
                @elgur hmmm should work out of the box then, are you sure they are synchronised with the dongle and not with your consoled or another dongle ?
                also do you use official image ?
                • ninjaw
                  ninjaw Banned last edited by
                  I confirm the pc usb Xbox360 dongle is working out of the box for me (except default keys, I had to remap)
                  • Benumb
                    Benumb last edited by
                    Same probleme here the circle always turn and not synchronized 😞
                    (Ihave a generic dongle)
                    • joinski
                      joinski last edited by
                      Attention!
                      For wireless Xbox 360 controllers you need a Wireless USB-Receiver especially for Xbox 360 Controllers (because it does not work over Bluetooth)
                      You can use the official from Microsoft (expensive) or cheap no-names (like this for example: https://www.amazon.com/Generic-Wireless-Gaming-Receiver-Xbox/dp/B01JC68MHU/ref=sr_1_5?ie=UTF8&qid=1522150751&sr=8-5&keywords=xbox+wireless+receiver&dpID=41yLAnR2urL&preST=SY300_QL70&dpSrc=srch)
                      ninjaw 1 Reply Last reply Reply Quote 0
                      • ninjaw
                        ninjaw Banned @joinski last edited by
                        @joinski here's your shortened official link http://a.co/c0Q1xh2
                        • Benumb
                          so I don't why my generic receiver don't work at all 😞
                          joinski 1 Reply Last reply Reply Quote 0
                          • joinski
                            joinski @Benumb last edited by
                            @benumb
                            can you test, if your generic receiver works with a windows pc? when it does not work on a windows pc also, then maybe the receiver and/or the controller is not compatible or malfunctional.
                            Benumb 1 Reply Last reply Reply Quote 0
                            • Benumb
                              Benumb @joinski last edited by
                              @joinski yes, I didn't test it on PC.
                              I will do that for start ! 😉
                              • Benumb
                                Ok that's working, but the circle don't stop.
                                hard if if it s synchronized or not.
                                • Neitmer
                                  Neitmer last edited by
                                  I've the same problem.
                                  This manual ( https://github.com/recalbox/recalbox-os/wiki/Manual-(DE) ) say's, that I've to enable "controllers.xboxdrv.enabled" ... but i don't have this option (on version 18.03.30).
                                  Thanks for all your answers!
