    All my Nintendo 64 games doesn't work
    Emulator Arcade/PC/Console
    nintendo doesnt
    6
    16
    8407
    • A Former User
      A Former User last edited by
      Hi, my set worked perfectly before. I just installed the new update and any N64 goes to a black screen.
      Any ideas? Thanks!
      OyyoDams jorgemagana 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @Guest last edited by digitaLumberjack
        @deletedaccount nothing has been updated about N64 emulation in the latest version.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @OyyoDams last edited by
          @oyyodams Then what could possibly be the issue? Because I've seen some people posting on recalbox facebook forums that they got the same issue after updating. No one have been able to give these people an answer. That's why I made the topic.
          Are there steps I can do or something?
          Thanks.
          OyyoDams Substring 2 Replies Last reply Reply Quote 0
            @deletedaccount I know what forum you're talking about, and I know all these people, including you, from the beginning, are using modified pre-packaged images of Recalbox. I don't know what the official upgrade can do on a modified image. So I can't offer you any support.
            If you read the official forum (here), there are no such issues.
            My only advice is to stop this activity, and start a fresh and clean install with the official Recalbox version.
              Substring @Guest last edited by digitaLumberjack
              @deletedaccount start a n64 game then post a support archive
              • A Former User
                A Former User @OyyoDams last edited by digitaLumberjack
                @oyyodams If you'd know me you would know that I do my OWN builds and never downloaded anyone else's image!
                I made a fresh install on a brand new SD card just this morning and tested the N64 to see that it's not working anymore.
                @substring said in All my Nintendo 64 games doesn't work:
                Hi thanks for your answer, just to be sure I start a N64 game and then go in the recalbox manager and export a support file?
                Thanks!
                OyyoDams Substring voljega 4 Replies Last reply Reply Quote 0
                  @deletedaccount go to the web manager, support section, execute the support script, and paste here the link you get.
                    @deletedaccount yeah. But still, nothing changed on our side, so guess where the problem comes from ... I have no idea what your build is, on what it is based, what mods you've done etc ... And as @OyyoDams said, if N64 really didn't work, the forum would be full of complains. But it's not. So once again, guess where the problem comes from ...
                      voljega Banned @Guest last edited by digitaLumberjack
                      @deletedaccount I did a fresh install too and it work for me
                        Then someone will have to sort this out on his own as i believe the image he's using is jusy badly customized. We don't like wasting our time on non genuine recalbox images.
                          @deletedaccount said in All my Nintendo 64 games doesn't work:
                          yes
                          • jorgemagana
                            jorgemagana @Guest last edited by digitaLumberjack
                            @deletedaccount Same problem here, but solved using uncompressed files.
                              paradadf Staff @jorgemagana last edited by digitaLumberjack
                              @jorgemagana said in All my Nintendo 64 games doesn't work:
                              About this and as I as told you on the spanish topic, the default n64 emulator is the standalone mupen64plus version which has never supported compressed files, so it is impossible that the games just stop working, as you must have change the default emulator yourself before.
                              jorgemagana 1 Reply Last reply Reply Quote 0
                              • jorgemagana
                                jorgemagana @paradadf last edited by
                                @paradadf agradezco tu ayuda y comentarios. Este foro es para apoyarnos.
                                  @jorgemagana mi comentario solo pretendia aclarar que en recalbox nunca recomendamos usar archivos comprimidos con n64.
                                  • jorgemagana
                                    @paradadf said in All my Nintendo 64 games doesn't work:
                                    Entendido, gracias!
