    PSP not showing up?
    psp showing
    5840
    • BlackAzrael
      BlackAzrael last edited by
      Hi,
      So I recently updated the recalbox to the newest version.
      I tried putting psp roms in the psp folder but the psp section is not showing up.
      I'm not sure if I'm doing anything wrong here, I tried both .cso and .iso, but still nothing showing up.
        Hello @BlackAzrael
        only rpi3, ordoid or x86 for psp
        https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
        • BlackAzrael
          I have the RPI3, when I tried it in 4.1 unstable it showed up.
            OyyoDams Staff @BlackAzrael last edited by
            @blackazrael Hi, can you make a support archive ? Go to the web interface with your browser, support section, make a support archive, and paste the link here.
            • BlackAzrael
              Ok, I think that's what you mean?
              https://file.ac/lwoi3WS1vF8/
                @blackazrael ok nothing seems to be wrong.
                Please check that your roms are in ".cso/.iso/.pbp" format in the psp folder and reboot.
                • BlackAzrael
                  BlackAzrael last edited by BlackAzrael
                  Haha I actually fixed it, the psp system wasn't showing in es_systems.cfg since I kept my old custom one.
                  Showing up fine now!
                  I do have other questions though.
                  1. Is there any performance advantages between .iso and .cso for psp?
                  2. The N64 emulator only shows a limited square, like say it was set to 640x480, it only covers that much of the 1080p TV and the rest is black
                  3. Are there optimized settings for the PSP?
                  Thanks!
                    Substring @BlackAzrael last edited by
                    @blackazrael said in PSP not showing up?:
                    No idea, to be honnest. Anyway emulators also emulate the access speed to disk devices most o times (not sure abt ppsspp though)
                    1. The N64 emulator only shows a limited square, like say it was set to 640x480, it only covers that much of the 1080p TV and the rest is black
                    That's a tv setting problem, it should resize to 640x480 tonfill the screen
                    1. Are there optimized settings for the PSP?
                    Thanks!
                    Give a try to multi processing and auto frameskip
