    Hard disk installation
    hard installation
    23033
    • LRN
      LRN last edited by LRN
      Hi
      I want to put Recalbox on the second hard drive. The version for computers (PC 64 bits - x86_64). At boot, I will choose from which disk is loaded.
      I have a computer running Windows 10, how can I do it (did not find any descriptions)?
      Thank you!
      p.s. sorry for my translation
        Substring @LRN last edited by
        @lrn hi
        Using etcher avdanced mode, you can burn the img to a hard drive. Make sure not to erease an unwanted disk
        • LRN
          LRN last edited by
          How to burn an image to a hard drive from under Windows 10? All utilities write to flash drive ...
            OyyoDams Staff @LRN last edited by OyyoDams
            @lrn like @Substring said, use Etcher... in unsafe mode to enable write on hard disk.
            • LRN
              LRN last edited by
              What should be done? He does not give you the choice of a drive!
              My second disc is divided into two parts - is not that a problem?
              alt text
              Thank you!
                @lrn Is your Windows currently using 😧 or F: drive ?
                And where recalbox.img.xz is located ?
                • LRN
                  LRN last edited by
                  Disk D:/
                  OyyoDams 2 Replies Last reply Reply Quote 0
                    @lrn you can't flash this disk... because the image is on this disk. Put the image on 😄
                      @lrn But be carefull, it will erase both 😧 and F: !
                      • LRN
                        LRN last edited by
                        I have two disks on my laptop.
                        1. System (Windows 10) (C/:)
                        2. The disk is divided into two sections (D:/ + F:/)
                          alt text
                        I want to install the recalc box on the disk F:/
                        Now he chooses two sections at once
                        alt text
                          @lrn you can't install on F: only. The installation will erase the whole drive.
                          Recalbox is an Operating System, which creates its own partitions. That's why you can't install it in an existing partition.
                          • LRN
                            If you put Recalbox, and then Acronis change partitions. Is this possible?
                            I do not have, not a monitor, no TV. Therefore it is necessary so to get out, without Raspberry Pi!
                              @lrn you don't have a usb key on which you could burn reclbox and then boot your laptop on it ?
                              • LRN
                                LRN last edited by
                                The hard drive is more convenient + 10 places more!
                                  @lrn in this case you have to use the whole hard drive. Currently you can't install Recalbox and keep other partitions.
                                  • LRN
                                    Thank you for the detailed and fast response!
                                    Question:
                                    Can I change the sound driver? I have a noise after the launch. Noise overlaps the sound (there is sound, but noise is louder). Noise - Pphhhhhhhhhhhh...
                                    Sound card: Realtek ALC269
                                    • mikejones
                                      mikejones Banned last edited by
                                      This post is deleted!
