    Error during the installation of Recalbox on Raspberry Pi 3
    raspberry pi 3 recalbox sdcard error installation
    6405
    • MikołajHenza
      MikołajHenza last edited by
      Hi,
      When I try to install the soft on my Raspberry, I see this communicat:
      This error
      I tried everything I know - renaming the SD card (BOOT), substitiuting the card to other. Please help me with it
        OyyoDams Staff @MikołajHenza last edited by
        @mikołajhenza Hi,
        This seems to be the Noobs install. Please try the direct install from our website.
        https://archive.recalbox.com/
        • MikołajHenza
          MikołajHenza last edited by MikołajHenza
          Hi @OyyoDams
          I tried this from the beginning but installing image on my disk unfortunetlly doesn't work. I only copied files like this:
          Do you think I need to install the NOOBs?
            @mikołajhenza Please follow the recommended method: use Etcher to write the image from our website on your SD card.
            MikołajHenza 1 Reply Last reply Reply Quote 0
            • MikołajHenza
              MikołajHenza @OyyoDams last edited by
              @oyyodams I was doing that every time but it doesn't work for me
                @mikołajhenza what do you mean by "it doesn't work" ? Can you give more details ?
                • MikołajHenza
                  @oyyodams It simply doesn't work. There isn't any signal on the monitor and only red light works.
                    @mikołajhenza what is your SD card manufacturer ?
                    • MikołajHenza
                      MikołajHenza @OyyoDams last edited by MikołajHenza
                      @oyyodams I use two cards - first is SanDisk 16GB MicroSD HCi (Class 10 which has installed Rasbian, it's from https://botland.com.pl/karty-pamieci-raspberry-pi/8848-karta-pamieci-microsd-16gb-40mbs-klasa-10-system-noobs-dla-raspberry-pi.html) and second is Kingston C32G. I tried to do that on both of them and they are FAT32.
                        @mikołajhenza ok forget the Kingston. The Sandisk should work, maybe you should re-download the image from our website.
                        Etcher will format the SD card, so I don't care if it's FAT32 or NTFS before 😉
                        • MikołajHenza
                          @oyyodams I did it on this card few times... It doesn't work, i used Etcher and Win32DiskImager
                            @mikołajhenza so it seems you have bad luck with both SD cards... With noobs or direct image... I can only advise you to buy another good SD card (Sandisk class 10 are the best ones)
                            • MikołajHenza
                              @oyyodams But why on YouTube tutorials they always show to copy files to he SD card like me.
                                @mikołajhenza these are old tutorials.
                                This is the up to date (in french): https://www.youtube.com/watch?v=1UBH4S6kG80
                                • MikołajHenza
                                  @oyyodams Can you see that is everything OK with my card?
