    Raspberry pi 3 Recalbox Latest. Roms wont work or run with problems
    Your recalbox
    recalbox latest roms wont run
    • trippy86
      trippy86 last edited by
      Hi all
      saw a friend using recalbox and i liked it so much more than retropie i decided to move over.
      Problem i am finding is not many of my roms work correctly anymore. Some are ok or they either dont load or load with sound problems. Didnt have this issue before so im hoping there are some settings i can change
      Any suggestions as to what i can do? thanks so much
      • idarius
        idarius last edited by
        hi,
        • what is your hardware ? (Rpi3?)
        • what's your actual recalbox version ?
        • are you sure all your roms are good ? you can test them with an emulator on pc, or maybe get the same roms from your friend to test.
        i've a LOT of games for all system and i don't have any problem with any rom.
        • trippy86
          hi
          Rpi3 fully updated
          latest version of recalbox
          all roms work fine on pc and on retropie
          thx
            OyyoDams Staff last edited by
            Can you make an support archive ?
            Please connect to Recalbox web interface with your web browser, go to support, execute the script, and paste the link you'll get here.
