    Assign a different piece of music to each system page?
    assign different piece music each
    3993
    • Sylvester
      Sylvester last edited by
      After getting a music file that is in .ogg format (256kbps, 44100Hz),
      Where in the file structure would I need to place the file in order for that piece of music to play just when that system page is accessed in recalbox?
        Substring @Sylvester last edited by
        @sylvester That is something that depends on the themes
        Sylvester 1 Reply Last reply Reply Quote 0
        • Sylvester
          Sylvester @Substring last edited by
          @substring
          I believe I'm using the default theme.
          Could you give an example of where each .ogg should go in this case?
          Substring paradadf 2 Replies Last reply Reply Quote 0
            @sylvester No idea, that's definitely what i do not take care of. @rockaddicted or @supernature2k or @paradadf should be able to tell you
            • Sylvester
              @substring
              Okay thanks!
              I shall wait their arrival
                paradadf Staff @Sylvester last edited by
                @sylvester I haven’t look into it, but I’d suggest you to get the simplelight ES theme and analize it. As far as I remember, it has custom music for every single system.
                • agahowa23
                  agahowa23 last edited by
                  Hi,
                  With the new Recalbox release (18.03.30) I would like to revive this topic, because I want to use the default theme (for obvious reasons) and add custom music to every system. Could someone please help me. I would ask for the Recalbox-Next theme, but I know it won't be that easy.
                  supernature2k 1 Reply Last reply Reply Quote 0
                  • supernature2k
                    supernature2k @agahowa23 last edited by
                    @agahowa23
                    Hi, please make at least a bit of search 🙂
                    this is as simple as this:
                    in the main theme.xml add the following tag under system view:
                    <sound name="bgsound">
                       <path>./$system/put_it_wherever_you_want/with_same_file_name_for_every_system.ogg</path>
                    </sound>
                    What it will do:
                    • replace $system with the name of each system
                    • load the file (that's why all files should have the same name)
                    agahowa23 1 Reply Last reply Reply Quote 0
                    • agahowa23
                      agahowa23 @supernature2k last edited by
                      @supernature2k
                      I am immensely grateful with you! I swear I made my research in the forum and I found many topics that talked about this, but none of them were conclusive (the ones I saw). I found one that I think was the one I needed but it was in french, I translated with google translator, but I wasn't much of a help.
                      I found difficult to find the main theme.xml (even with WinSCP) but I did it.
                      I am truly grateful, thanks! You all make a great job!
