    Force either 1080p or 720p everywhere
    force either 1080p 720p everywhere
    6267
    • ThomasD3
      ThomasD3 last edited by ThomasD3
      Is there a way to force a specific resolution both for the menu and the emulators?
      I have a TV that takes ages when switching from 1080p <-> 720p and I'd like to find a way to lock the resolution.
      I have changed the setting in /recalbox/share/system/recalbox.conf and /recalbox/share_init/system/recalbox.conf to set 1080 but it still toggles between 1080p in the menu and 1080i in the games.
      (I found that the Atari 2600 emulator crashes in 1080p)
        Substring @ThomasD3 last edited by
        @thomasd3 We wouldn't recommend 1080p for playing. So you just need to edit /boot/config.txt to force CEA 4
        ichitaka 1 Reply Last reply Reply Quote 0
        • ThomasD3
          What's the relationship between the different config files?
          I found video settings in:
          /boot/config.txt
          I feel a bit lost 🙂
            @thomasd3
            • /boot/config.txt is a kind of bios parameter file for the pi. You can eventually set the native display resolution there to overpass the EDID from your TV/screen
            • regarding the recalbox.conf file, one is the default (in share_init), the other is the every day one. It's a recalbox specific parameters file, and holds values for the screen resolution for emulators among many other things
            If you set CEA 4 in the config.txt, it will be considered as your default resolution. I strongly recommend you set global.videomode=default in the recalbox.conf to avoid resolution changes
            • ichitaka
              ichitaka @Substring last edited by ichitaka
              @substring said in Force either 1080p or 720p everywhere:
              why 1080 its not recommend?
                Hello
                vram issue.
                Please not up old subject
